Full Version: Remote says "no tv shows"
So all of a sudden my android remote says "no tv shows" and "no movies" and i have to manually go to movies and shows via the onscreen menus instead.
Any idea whats going on? Smile
Running XBMC 11.0 Stable
Remote version 1.0.9 Build 1009.
Official is broken for Eden ATM upgrade to Frodo or try alternatives Smile
Lol I didnt even know Frodo had came Big Grin
Thanks, I'll try it out Smile
Now I've updated.
When i try to go via the "Tv shows" or "movies"-menu in the android-app, XBMC starts to load (the animated circle) and then hangs after 5-10 seconds.
If i use the app as a remote and go thru XBMCs own menus it works fine..
Suggestions?
