(2017-01-19, 22:12)fishplish Wrote: [ -> ]Hello enen92,
I have the Kodi v16.1, i made à update ans now Rtp play live is not working anymore.
Do you have explication? And solution ?? Thanks for your help!!
The plugin needs an update. It is already sent to the repository:
https://github.com/xbmc/repo-plugins/pull/879
It should be available by tomorrow. If you're in a hurry just grab the code from my github
Cheers
(2017-01-18, 07:15)JoelyMoley Wrote: [ -> ]Hey enen92,
first, thankyou so much for your work! im hoping to install this repo as a solution for my portuguese parents that live in australia. I've just checked the SIC and TVI website and it appears that both actually have livestreams now, is there any chance of having these included in this addon? Here are the links to each stream:
http://sic.sapo.pt/direto
http://tviplayer.iol.pt/direto/TVI
thankyou again.
Joel.
Not in this addon, it is only RTP.
There is a tviplayer addon maybe it supports the live stream? For sic, maybe its easier to create a .strm file with the video stream link
Enviado do meu A0001 através de Tapatalk
Hello enen92,
I've been enjoying the RTP Play add-on for a number of years now. I very much appreciate your work. Thank you. Over the last few days, perhaps since the last update, I found that the recorded shows do not play. The live channels work fine however.
Thanks,
Fernando
Hey fernando, should be fixed in the next version (by the end of the night or tomorrow). cheers
PS: Thanks for reporting. I don't use the plugin much so, please always let me know when it breaks.
That's great! Thank you.
Olá enen92,
RTPPlay não está a funcionar
Obrigada
JM
[/quote]
Please use english - this is an english forum.
Have already fixed it:
https://github.com/enen92/plugin.video.rtpplay
Will submit the update to the repository in a few minutes (however it can take a while to be available). If you're in a rush, just grab the version from my github.
edit: sent to repo as well:
https://github.com/xbmc/repo-plugins/pull/963
[/quote]
I am sorry for my lapse of not writing in English
Thank you for the update
JM
enen92! when you can do new updates to rtpplay?
(2017-03-01, 19:07)Morteiro Wrote: [ -> ]enen92! when you can do new updates to rtpplay?
Is there any specific reason? Is there anything that is not working?
My goal with the plugin is keeping it working. It exists for a few years now and it is on the Gotham repository. This means it works for all Kodi versions since Gotham. It does what a plugin is suposed to do: lists videos and plays them.
in the archives, in is sub-sections don't apear anything.
Enen92 - I'm currently running kodi 17.1 "20170404" on my AppleTV 4. I notice with RTP Play no live streams will play video or sound but the radio channels work. Am I missing something. Your help will be highly appreciated. Thank you
Sent from my iPhone
(2017-05-09, 04:39)ferreira520 Wrote: [ -> ]Enen92 - I'm currently running kodi 17.1 "20170404" on my AppleTV 4. I notice with RTP Play no live streams will play video or sound but the radio channels work. Am I missing something. Your help will be highly appreciated. Thank you
Sent from my iPhone (typie typie)
It works okay on all my platforms. Note that the atv4 is not yet a stable platform to run Kodi on
(2017-05-10, 22:36)enen92 Wrote: [ -> ] (2017-05-09, 04:39)ferreira520 Wrote: [ -> ]Enen92 - I'm currently running kodi 17.1 "20170404" on my AppleTV 4. I notice with RTP Play no live streams will play video or sound but the radio channels work. Am I missing something. Your help will be highly appreciated. Thank you
I figured it out. I disabled Video Hardware Acceleration under Kodi Settings. Works like a charm now. Thank you for your reply.
Sent from my iPhone
Hi enen92,
I am using the RTP Play addon on my iPad using Kodi 17.3, iOS version 9.0.2 and every time i select a stream to watch a channel the entire kodi app crashes. Any idea what may be causing this. It works great on my android devices running 17.3. Thanks again for the great addon.
