Since I updated to Frodo from Eden and from Nox 3 to 4, my local logo and clearart have stopped displaying.
Any help would be appreciated
Read the FAQ like you should have!!!
run artworkdownloader to rescan your logos and clearart into your libary.
And make sure you have "Use Local Files" checked
First, you need ArtworkDownloader. Get it elsewhere.
Then you need to turn on Use Local Files in the ArtworkDownlader settings. Do not search yet.
Then check all your Nfos for the <ID></ID> tag, and make sure it's filled out.
Then readd (if) any shows/movies that was missing the tag.
Now you have my permission to search.
Thanks guys! Setting ArtworkDownloader to "Use local files" resolved my issue with logos not displaying from within the directory as "logo.png" with XMBC 12 Frodo.
Logos used to work natively by dropping the logos into the directory with XBMC 11 Eden, but that stopped working with the error "logo missing" when I upgraded to Frodo.
Once I configured AD correctly and then rescanned the art, everything appeared.
Thanks again!
How would I go about getting my logo.png setup for artists when in full screen visualisation mode?
I have my library sorted as ARTIST\ALBUM with the logo.png off the root of ARTIST folder
