2013-02-04, 00:36
When I try to start XBMC Frodo, running on Ubuntu 12.10 - it crashes with a segmentation fault. I can run it from the command line with 'sudo xbmc' or from the gui with gksudo xbmc - but do not want to have to do that. Here is the crash log:
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Thu Jan 31 23:07:29 EST 2013
XBMC Options:
Arch: i686
Kernel: Linux 3.5.0-22-generic #34-Ubuntu SMP Tue Jan 8 21:41:11 UTC 2013
Release:
Distributor ID: Ubuntu
Description: Ubuntu 12.10
Release: 12.10
Codename: quantal
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /home/gregg/core (2013-01-31 23:07:29.372453961 -0500)
[New LWP 22560]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/i386-linux-gnu/libthread_db.so.1".
Core was generated by `/usr/lib/xbmc/xbmc.bin'.
Program terminated with signal 11, Segmentation fault.
#0 0x00000000 in ?? ()
Thread 1 (Thread 0xb51db700 (LWP 22560)):
#1 0xb77c7cf2 in connect () from /lib/i386-linux-gnu/liblsp.so
#2 0xb77b5b0f in ?? () from /usr/lib/i386-linux-gnu/pkcs11/gnome-keyring-pkcs11.so
#3 0xb77b644e in ?? () from /usr/lib/i386-linux-gnu/pkcs11/gnome-keyring-pkcs11.so
#4 0xb58826ef in ?? () from /usr/lib/i386-linux-gnu/libp11-kit.so.0
#5 0xb5883078 in ?? () from /usr/lib/i386-linux-gnu/libp11-kit.so.0
#6 0xb58839b9 in p11_kit_initialize_registered () from /usr/lib/i386-linux-gnu/libp11-kit.so.0
#7 0xb5ae93eb in gnutls_pkcs11_init () from /usr/lib/i386-linux-gnu/libgnutls.so.26
#8 0xb5acfd4a in gnutls_global_init () from /usr/lib/i386-linux-gnu/libgnutls.so.26
#9 0xb714a784 in MHD_init () from /usr/lib/i386-linux-gnu/libmicrohttpd.so.10
#10 0xb77dde9b in ?? () from /lib/ld-linux.so.2
#11 0xb77ddf84 in ?? () from /lib/ld-linux.so.2
#12 0xb77d020f in ?? () from /lib/ld-linux.so.2
############# END STACK TRACE ###############
################# LOG FILE ##################
Logfile not found in the usual place.
Please attach it seperately.
Use pastebin.com or similar for forums or IRC.
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
XBMC Options:
Arch: i686
Release:
Release: 12.10
Codename: quantal
[New LWP 22560]
