Full Version: Old Aeon Nox Backdrops and Changing Splash Screen
Hi all, I am looking for the old Aeon Nox Backdrops/Backgrounds, There has been another post about this before but the links just point to the current github location and the backgrounds are the same as the ones I have.
I am looking for these ones; Image
I am also hoping to replace the Aeon Nox Splash screen (the one that appears after the XBMC splash screen) but I can't seem to find it. Is it possible to replace this image??
I think your best chance would be here. Check the backgrounds folder inside the zip file.
Thanks for the help. I already found version 3.5 but it still uses the grey scale backdrops.
I am pretty sure version 3 was the last one to use the coloured backdrops, but I could be wrong
use nox extras downloader.
Got it, thanks heaps.
So does anyone know how to change the AEON splash screen?
