2013-02-04, 02:45
2013-02-04, 14:41
If you tell us what the "fake autosizing button" technique looks like, we might be able to help.
2013-02-04, 16:11
Where you have a set of horizontal buttons hidden then use a grouplist of labels referencing those buttons so they can use the autosize feature of labels to keep the spacing the same between them...
.xml example
Line 630 is the group of buttons
Line 711 is the grouplist of labels
.xml example
2013-02-04, 16:42
You can e.g. use an animation for the labels and fade them if a button is disabled:
PHP Code:
<animation effect="fade" end="50" time="0" condition="!Control.IsEnabled(id)">Conditional</animation>
2013-02-04, 17:17
Control.IsEnabled(id), THX...
2013-02-04, 18:08
Or hide the button altogether with if it's not enabled and then the labels using .
Control.IsVisible(id)
