Skins Support
Skin Archive
Transparency!
> Sorting of folders & movies
Full Version:
You're currently viewing a stripped down version of our content.
View the full version
with proper formatting.
antoniong
2013-02-04, 21:04
I always use the Files menu. Presently folders are in front of movies. Is there a setting to arrang them that they all are in alohabetical order so that single movies and subfolders are mixed?
artrafael
2013-02-04, 21:41
On your movies list page, open the left slider menu and select Sort by: File.
antoniong
2013-02-04, 21:46
Thanks, the problem is that there is a myriad of settings making finding the correct one sometimes a problem.
Skins Support
Skin Archive
Transparency!
