SSH to your box and do the following
1)
sudo cp /etc/fstab /etc/backupfstab
2)
Change your fstab This is the command i used...
****but beware if this doesnt work on yours it will mess things up:
sudo sed -i 's/errors=remount-ro/errors=remount-ro,user_xattr/' /etc/fstab
safer method is to:
sudo /etc/fstab
and add ,user_xattr after errors=remount-r on your / fs the line should look something like this when its done
UUID=XXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX / ext4 errors=remount-ro,user_xattr 0 1
3)
sudo vim /etc/X11/xorg.conf
(if you dont have it sudo apt-get install vim)
change the Disable for Composite to Enable like this:
Option "Composite" "Enable"
4)
sudo mount -o remount /
sudo apt-add-repository ppa:ehoover/compholio -y
sudo apt-get update
sudo apt-get install netflix-desktop -y
5)
download the following file and install it from addons from zip file
Downlad Zip Addon here
go to videos and addons click on netflix...
youll need a keyboard and mouse to control netflix... it will also install a bunch of needed packages
I have gotten netflix working on xbmcuntu; here's the workarounds i have come up with.
first off, i would run the install and run netflix-desktop from a desktop session, not from xbmc the first time.
it will have to download and install some bits to get itself set up.
second- on having it grab focus: i've found this to be a problem in alot of situations involving external applications because controlling focus is usually the job of the window manager, and XBMC doesn't run one nor need one for most things it does as xmbcuntu in the stand-alone configuration. .
my solution is this script:
#!/bin/bash
openbox &
netflix-desktop "$1"
kill %1
what this script does is run the open box window manager in the background, then open netflix-desktop.
once netflix-desktop exits, it kills the open box.
having a window manager running will automatically assign focus to the new window, witch is full screen so there won't be any window decoration. \
right now i am using advanced launcher to launch netflix; i may try and hack my way into one of the browser plugins that is already out there as that's a cleaner, more integrated way to do it that takes advantage of the groundwork done by others on the windows platform.
one other error i came across was that i needed to edit /etc/X11/xorg.conf to enable compositing.
Thank you - Ill give that a try...
You're right i forgot to mention that..
in /etc/X11/xorg.conf the Composite needs to be enabled (i think this may only hold true for nvidia cards from what I read)
Section "Extensions"
EndSection
How is your playback on your system?
it's pretty much flawless- we watched two movies last night and the load average averaged from 1.9-1.7 with piles of memory left available.
now, my setup is a bit 'dated' to say the least- it's an upgraded $100 special from the local PC recycler here in seattle, RE-PC.
it's a dell pavilion d4650y.
Core 2 Duo 1.86 GHz
6.5 gig of memory
GeForce 7300 LE
i also have Mythtv-backend running on this thing, with a Ledtek HDTV cinema tuner card.
display is via S-video to a 1991-era toshiba CRT TV.
so while the system is modest, i'm not asking it to do HD, either. however, to get some extra headroom for this and running handbrake i am currently saving up the $60-$80 to upgrade to a q6600 or q6700 quad core 2.4-2.6ghz processor, the fastest this old board supports.
Did you have to make any other changes?
Im thinking my audio or something might not be set right to work with openbox?
but I am running hdmi and passing audio that way but on this box an ion2 and i can stream bluray isos from my nfs server...
I also have a myth-backend with 2x hdhomerun 3s
the new pvr merge is nice!
I tried installing this on Eden, running on ubuntu. It's not xbmcbuntu, but I have it set up to boot right into xbmc with lightdm. I got to step 5, but got hit with an error, "Netflix dependencies not met."
Any ideas?
Havent tried it on Ubuntu Eden..
Are you saying that you get the error, when you try to install the addon zip file in xbmc? or before that?
It happens when I try to install the addon file.
If you go into the /home/<user>/.xbmc/addons dir you should see the extracted files i believe.
You might have to take a look at the addon.xml file (I may have put in a version number that required it to be on frodo) if you google xbmc addon xml you should find the page that has the version dependencies listed..
also what does your log say?
/home/<user>/.xbmc/temp/xbmc.lolg
Here's the contents of the addons directory.
metadata.albums.allmusic.com plugin.video.twitch script.tv.show.next.aired
metadata.album.universal plugin.video.vimeo script.tvtunes
metadata.artists.allmusic.com plugin.video.youtube script.watchlist
metadata.artists.universal script.artistslideshow script.xbmc.blindplayer
metadata.common.allmusic.com script.artwork.downloader script.xbmc.debug.log
metadata.common.fanart.tv script.artworkorganizer skin.back-row
metadata.common.hdtrailers.net script.commands skin.confluence-vertical
metadata.common.htbackdrops.com script.common.plugin.cache skin.mediastream_redux
metadata.common.imdb.com script.favourites skin.metropolis
metadata.common.last.fm script.globalsearch skin.neon
metadata.common.musicbrainz.org script.image.bigpictures skin.quartz
metadata.common.theaudiodb.com script.module.beautifulsoup skin.rapier
metadata.common.themoviedb.org script.module.buggalo skin.xeebo
metadata.musicvideos.last.fm script.module.elementtree skin.xperience-more
metadata.themoviedb.org script.module.parsedom skin.xtv-saf
metadata.tvdb.com script.module.requests weather.weatherplus
packages script.module.simple.downloader weather.worldweatheronline
plugin.audio.groove script.module.xbmcswift webinterface.awxi
plugin.image.google script.module.xbmcswift2 webinterface.home-row
plugin.image.picasa script.mythbox webinterface.pwi
plugin.video.academicearth script.playalbum webinterface.wtouch
plugin.video.nasa script.pseudotv webinterface.XWMM
plugin.video.pbs script.randomitems
plugin.video.pennyarcadetv script.rss.editor
I don't see a version requirement for frodo in the xml file, but there's the text, in case I'm missing something.
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<addon id="netflix_install" name="Netflix" version="0.0.1" provider-name="fnc1">
<requires>
<import addon="xbmc.python" version="2.1.0" optional="true"/>
</requires>
<extension point="xbmc.python.script" library="default.py">
<provides>video</provides>
</extension>
<extension point="xbmc.addon.metadata">
<summary lang="en">Installs netflix-desktop and Adds an icon for Netflix.</summary>
<description lang="en">Installs netflix-desktop and Adds an icon for Netflix.</description>
<platform>linux</platform>
<language>en</language>
</extension>
</addon>
Here's what I found in the log.
22:56:46 T:139988528252672 NOTICE: Thread Jobworker start, auto delete: true
22:56:50 T:139990177965952 ERROR: Texture manager unable to load file: /media/godzilla/script.netflix_install-001.zip/icon.png
Looks like an issue loading the icon.png file. I copied the file out of the zip and it didn't appear corrupted, so I'm unsure what the issue is.
yeah i think it gives the icon error when there is a version issue..
try changing the version here this is set for frodo
see here
http://wiki.xbmc.org/index.php?title=Addon.xml
section 2.1.2 for the current versions table (and pick yours under xbmc.python.
once you change that inside the dir
you should be able to rezip it and install it
you might have to do a
sudo apt-get install zip (or something like that)
then
zip -ur script.netflix_install-custom.zip script.netflix_install-001/
then install your custom one
That did the trick, got the message that said "Netflix enabled.
But, in video add-ons, I click on Netflix and nothing happens. Under the information dialogue, it shows the status as "disabled".
like i said i pretty much set this up to just work with frodo... Im not sure why it would be disabled...
but do you have openbox installed - thats what is used to launch it..
i suppose you could try editing the run.sh file i think it is and put replace openbox with lightdm (which is what i think you were using) but i dont know how this will work...
the other thing is you may try installing openbox.
also try to uninstall then reinstall the addon....
and make sure to check your log files. xbmc.log Might say why it is disabled.
I do not understand
when i do " sudo vim /etc/X11/xorg.conf " i come to a empty file, what should i do? wright "Option "Composite" "Enable" " in it? and how do i exit it ?
you can try without... i *Think that is a specific to nvidia cards...
