2013-02-06, 08:02
Hello everybody,
I have an apple tv 4.3 (8F455), I just jailbroken and installed "Frodo", when I play a movie via wifi off my computer crashes from time to time, say in the minute 20 or so...
I have to say that I also have NitoTV which crash when trying to install apps, so I don't use, does it have anything to do?..should I install it?
Syslog
http://pastebin.com/9JahXLtS
Crashreport
http://pastebin.com/aAHStP5r
Few minutes later again:
Syslog:
Feb 5 21:53:54 Apple-TV com.apple.frontrow[472]: Connections:
Feb 5 21:53:54 Apple-TV com.apple.frontrow[472]: node 2 bus 0 => node 1 bus 0 [ 2 ch, 44100 Hz, 'lpcm' (0x00000C2C) 8.24-bit little-endian signed integer, deinterleaved]
Feb 5 21:53:54 Apple-TV com.apple.frontrow[472]: node 3 bus 0 => node 2 bus 0 [ 2 ch, 44100 Hz, 'lpcm' (0x00000C2C) 8.24-bit little-endian signed integer, deinterleaved]
Feb 5 21:53:54 Apple-TV com.apple.frontrow[472]: node 4 bus 0 => node 2 bus 1 [ 2 ch, 44100 Hz, 'lpcm' (0x00000C2C) 8.24-bit little-endian signed integer, deinterleaved]
Feb 5 21:53:54 Apple-TV com.apple.frontrow[472]: CurrentState:
Feb 5 21:53:54 Apple-TV com.apple.frontrow[472]: mLastUpdateError=0, eventsToProcess=F, isRunning=T (1)
Feb 5 21:55:54 Apple-TV freemem-watcher[504]: Check apsd memory usage...
Feb 5 21:55:54 Apple-TV freemem-watcher[510]: Process apsd not found
Feb 5 22:04:13 Apple-TV ReportCrash[511]: Formulating crash report for process AppleTV[472]
Feb 5 22:04:13 Apple-TV ReportCrash[511]: libMobileGestalt loadBasebandMobileEquipmentInfo: Could not establish connection to commcenter
Feb 5 22:04:13 Apple-TV ReportCrash[511]: libMobileGestalt copyInternationalMobileEquipmentIdentity: Could not get mobile equipment info dictionary
Feb 5 22:04:13: --- last message repeated 1 time ---
Feb 5 22:04:13 Apple-TV ReportCrash[511]: Saved crashreport to /var/mobile/Library/Logs/CrashReporter/AppleTV_2013-02-05-220413_Apple-TV.plist using uid: 0 gid: 0, synthetic_euid: 501 egid: 0
CrashReport 2
http://pastebin.com/S2SGA5Me
Does anybody experience the same?
Thank you!!!
Syslog
Crashreport
Syslog:
CrashReport 2
Thank you!!!
