Full Version: quick changes to audio output
i Use Optical output for daytime use & earphones for night time use
in eden ver 11 if i wanted to change the sound output it was done from Playback devices select default device. (via windows)
in frodo ver 12 this does not work, the only way i have found so far is in
System - Settings - System - Audio - Audio Output Device
i have two devices listed
SPDIF Digital Audio & DirectSound
only changing here changes the output
is there a hot key for cycling through enabled audio output from video playback without having to stop video and going back through settings
or another option
p.s. some things i watch are AC3 5.1
