Hi, I switched to vnsi from xvdr, since vnsi looks more stable meanwhile and fernet menta is doing a great job.
Only thing I am missing, is channel logos, like it is supported in xvdr.
PIcons can be downloaded here:
http://ocram.github.com/picons/downloads.html
Instead of matchin channel names, unique references are used, to find the correct channel logo. Details are described here:
https://github.com/pipelka/xbmc-addon-xvdr/issues/70
It would be nice, if either vnsi or the pvr part of xbmc in general would support those icons, because we would get maintained icons that will be added automatically to the correct channel.
Thanks,
Jobe
I'll put this on my looong list of to-dos
That´s bad, so I have to figure out the correct names for files by hand :-(
What's more important, perfect playback or nice looking icons?
I did not say no but there's some other tasks with higher prio.
(2013-02-07, 16:17)FernetMenta Wrote: [ -> ]What's more important, perfect playback or nice looking icons?
Aeh, ok, Perfect Playback is more important I guess
Ok, for those who would like to use picons and do not want to figure around with file names or add the icons manually. Here is a workaround based on turkbas picon scripts (
https://github.com/tkurbad/piconscripts)
Here is what you need to do:
- Downlaod picons (see initial post for the url) and save them to your vdr server
- Download attached python script and store it on your vdr server
- run the script the following way: python piconlinks.py -p /path/to/picons_dir -c /path/to/channels.conf >& create_links.sh
- change the directory to your picons directory and run the created "create_links.sh" script.
The python file creates the reference number for picons out of your entries in the channels.conf file. This reference numbers are used to find the correct *.png file for each channel. Having that in place a shell script is created that contains the instructions for creating the necessary links, so that the name of the icon files match your entries in channels.conf.
Note: This is a real quick and dirty hack, based on the existing piconscripts package, but it does the trick for me. Only thing currently not working is channel names with utf8 characters, but these should be very rear.
Hope someone else can use it too.
Kind regards,
Jobe
Edit: Link to the python script:
https://github.com/jobe39/piconscripts/b...onlinks.py
Ok, thanks. Python script ran fine... but now i don't know how to put that picon directry into by XBMC tree and/or if i need to fixup some xml config file so it will get used!
I am not in front of my computer. You should find it under Settings->Live TV. There you can set the dir for channel icons.
Works like a charm. Thanks.
You may want to change the subject of this thread to somethng like "[solved with workaround]"
so...after i run create_links.sh what else should i do?
Set the directory for tv icons in your xbmc settings, section live tv. Set it to the directory where you have downloaded the picons and run the script. Then you should have the icons for your channels in xbmc (maybe a few of them are missing).
Just tried this and it worked for a few icons, but many of them are missing, especially the ones for the HD channels, when there's a corresponding SD channel (e.g. Sky Cinema / Sky Cinema HD). Do I have to add them manually or can the script be altered to recognize these too? Or did I do something wrong?
I solved the issue myself by downloading a new version of one of the icon packs from
http://picons.bitbucket.org/downloads.html, I choosed
shd.transparent-white.tar.bz2, which fits good together with the Confluence skin. The script doesn't work for the latest version of the icon packs, because they changed the directory structure in the archives. I'm not a programmer guy, so I couldn't alter the script to work, but I found a workaround. The script expects the symlink png files containing the PID etc. to be in the same directoy like the actual png files. So I copied the PNGs to the main folder containing the symlinks (I used a command like
for i in `find . -name *.png`; do cp $i /home/xbmc/picons/iconpack; done; since the files are in subfolder like a, b, c, and so on) and after doing that, the
piconlinks.py script went through. The resulting
create_links.sh expects the actual PNG files to be in the subfolders where they were after unpacking, so after running create_links.sh, I removed the PNGs again from the main dir and moved the "old" symlinks to another sub dir, in case I need to update the files.
