Full Version: Parental controls crashing xbmc?
XBMC just a few days after installing from an EDEN disc, crashes on startup. It does what it always did but when "Parental Controls" flashes in the bottom right corner it just crashes.
If I - sudo xbmc, same results.
I tried to remove the parental-controls-settings.txt from .xbmc, tried deleting all entries so it's blank and looked for a folder for parental controls (couldn't find one).
I am running Frodo on 11.10
my crash logs are either the second one posted (probably not relevant) or this one which I got after messing with the parental-controls-settings.txt. It stays the same after replacing the original.
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Thu Feb  7 23:33:20 MST 2013
XBMC Options:
Arch: i686
Kernel: Linux 3.2.0-37-generic-pae #58-Ubuntu SMP Thu Jan 24 15:51:02 UTC 2013
Release:
    Distributor ID:    Ubuntu
    Description:    Ubuntu 12.04.2 LTS
    Release:    12.04
    Codename:    precise
############## END SYSTEM INFO ##############
############### STACK TRACE #################
gdb not installed, can't get stack trace.
############# END STACK TRACE ###############
################# LOG FILE ##################
23:33:18 T:3039042112  NOTICE: -----------------------------------------------------------------------
23:33:18 T:3039042112  NOTICE: Starting XBMC (12.0 Git:fb595f2), Platform: Linux (Ubuntu 12.04.2 LTS, 3.2.0-37-generic-pae i686). Built on Jan 28 2013
23:33:18 T:3039042112  NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
23:33:18 T:3039042112  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
23:33:18 T:3039042112  NOTICE: special://masterprofile/ is mapped to: /home/travalon/.xbmc/userdata
23:33:18 T:3039042112  NOTICE: special://home/ is mapped to: /home/travalon/.xbmc
23:33:18 T:3039042112  NOTICE: special://temp/ is mapped to: /home/travalon/.xbmc/temp
23:33:18 T:3039042112  NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
23:33:18 T:3039042112  NOTICE: Local hostname: XBMCenter
23:33:18 T:3039042112  NOTICE: Log File is located: /home/travalon/.xbmc/temp/xbmc.log
23:33:18 T:3039042112   ERROR: CAESinkOSS::EnumerateDevicesEx - Failed to open mixer: /dev/mixer
23:33:18 T:3039042112  NOTICE: Enumerated ALSA devices:
23:33:18 T:3039042112  NOTICE:     Device 1
23:33:18 T:3039042112  NOTICE:         m_deviceName      : default
23:33:18 T:3039042112  NOTICE:         m_displayName     : Playback/recording through the PulseAudio sound server
23:33:18 T:3039042112  NOTICE:         m_displayNameExtra:
23:33:18 T:3039042112  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
23:33:18 T:3039042112  NOTICE:         m_channels        : FL,FR,BL,BR,FC,LFE,SL,SR,UNKNOWN1,UNKNOWN2,UNKNOWN3,UNKNOWN4,UNKNOWN5,UNKNOWN6,UNKNOWN7,UNKNOWN8
23:33:18 T:3039042112  NOTICE:         m_sampleRates     : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
23:33:18 T:3039042112  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_U8
23:33:18 T:3039042112  NOTICE:     Device 2
23:33:18 T:3039042112  NOTICE:         m_deviceName      : iec958:CARD=PCH,DEV=0
23:33:18 T:3039042112  NOTICE:         m_displayName     : HDA Intel PCH
23:33:18 T:3039042112  NOTICE:         m_displayNameExtra: ALC892 Digital S/PDIF
23:33:18 T:3039042112  NOTICE:         m_deviceType      : AE_DEVTYPE_IEC958
23:33:18 T:3039042112  NOTICE:         m_sampleRates     : 32000,44100,48000,88200,96000,192000
23:33:18 T:3039042112  NOTICE:         m_dataFormats     : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
23:33:18 T:3039042112  NOTICE:     Device 3
23:33:18 T:3039042112  NOTICE:         m_deviceName      : hdmi:CARD=PCH,DEV=0
23:33:18 T:3039042112  NOTICE:         m_displayNameExtra: HDMI #0
23:33:18 T:3039042112  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
23:33:18 T:3039042112  NOTICE:         m_sampleRates     : 32000,44100,48000,88200,96000,176400,192000
23:33:18 T:3039042112  NOTICE:     Device 4
23:33:18 T:3039042112  NOTICE:         m_deviceName      : hdmi:CARD=PCH,DEV=1
23:33:18 T:3039042112  NOTICE:         m_displayNameExtra: HDMI #1
23:33:18 T:3039042112  NOTICE: load settings...
23:33:18 T:3039042112  NOTICE: special://profile/ is mapped to: special://masterprofile/
23:33:18 T:3039042112  NOTICE: loading special://masterprofile/guisettings.xml
23:33:18 T:3039042112  NOTICE: Getting hardware information now...
23:33:18 T:3039042112  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
23:33:18 T:3039042112  NOTICE: Loaded playercorefactory configuration
23:33:18 T:3039042112  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
23:33:18 T:3039042112  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
23:33:18 T:3039042112  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
23:33:18 T:3039042112  NOTICE: Loaded settings file from special://profile/advancedsettings.xml
23:33:18 T:3039042112  NOTICE: Contents of special://profile/advancedsettings.xml are...
                                            <advancedsettings>
                                              <useddsfanart>true</useddsfanart>
                                              <cputempcommand>cputemp</cputempcommand>
                                              <gputempcommand>gputemp</gputempcommand>
                                              <samba>
                                                <clienttimeout>30</clienttimeout>
                                              </samba>
                                              <network>
                                                <disableipv6>true</disableipv6>
                                              </network>
                                            </advancedsettings>
23:33:18 T:3039042112  NOTICE: Default DVD Player: dvdplayer
23:33:18 T:3039042112  NOTICE: Default Video Player: dvdplayer
23:33:18 T:3039042112  NOTICE: Default Audio Player: paplayer
23:33:18 T:3039042112  NOTICE: Disabled debug logging due to GUI setting. Level 0.
23:33:18 T:3039042112  NOTICE: Log level changed to 0
23:33:18 T:3039042112  NOTICE: Loading media sources from special://masterprofile/sources.xml
23:33:18 T:3036592960  NOTICE: Thread CSoftAE start, auto delete: false
23:33:18 T:3039042112  NOTICE: Running database version Addons15
23:33:19 T:3039042112 WARNING: CreateFile, error 20 opening file </home/travalon/.xbmc/addons/parental-controls-settings.txt/addon.xml>, flags:800, mode:124.
23:33:19 T:3026189120  NOTICE: Thread XBMC Peripherals start, auto delete: false
23:33:19 T:3039042112  NOTICE: Setup SDL
23:33:19 T:3039042112  NOTICE: Checking resolution 16
23:33:19 T:3039042112  NOTICE: Using visual 0x22
23:33:19 T:3039042112  NOTICE: GL_VENDOR = Tungsten Graphics, Inc
23:33:19 T:3039042112  NOTICE: GL_RENDERER = Mesa DRI Intel(R) Sandybridge Desktop x86/MMX/SSE2
23:33:19 T:3039042112  NOTICE: GL_VERSION = 3.0 Mesa 8.0.4
23:33:19 T:3039042112  NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.30
23:33:19 T:3039042112  NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_3DFX_texture_compression_FXT1 GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_
blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_NV_vertex_program GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_ATI_envmap_bumpmap GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_NV_vertex_program1_1 GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_MESA_ycbcr_texture GL_ARB_depth_clamp GL_ARB_
fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_rgtc GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_APPLE_object_purgeable GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_EXT_draw_buffers2 GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_MESA_texture_array GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_half_float_vertex GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_
texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_separate_shader_objects GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_ARB_ES2_compatibility GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_texture_lod GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_ARB_robustness GL_EXT_transform_feedback
23:33:19 T:3039042112   ERROR: GLX: Same window as before, refreshing context
23:33:19 T:3039042112  NOTICE: Running database version Addons15
23:33:19 T:3039042112  NOTICE: Running database version ViewModes4
23:33:19 T:3039042112  NOTICE: Running database version Textures13
23:33:19 T:3039042112  NOTICE: Running database version MyMusic32
23:33:19 T:3039042112  NOTICE: Running database version MyVideos75
23:33:19 T:3039042112  NOTICE: Running database version TV22
23:33:19 T:3039042112  NOTICE: Running database version Epg7
23:33:19 T:3039042112  NOTICE: start dvd mediatype detection
23:33:19 T:3039042112  NOTICE: initializing playlistplayer
23:33:19 T:3039042112  NOTICE: DONE initializing playlistplayer
23:33:19 T:2987621184  NOTICE: Thread CDetectDVDMedia start, auto delete: false
23:33:19 T:2980764480  NOTICE: Thread XBPyThread start, auto delete: false
23:33:19 T:3039042112  NOTICE: Previous line repeats 12 times.
23:33:19 T:3039042112  NOTICE: initialize done
23:33:19 T:3039042112  NOTICE: Running the application...
23:33:19 T:2770336576  NOTICE: Thread Jobworker start, auto delete: true
23:33:19 T:2830089024  NOTICE: -->Python Interpreter Initialized<--
23:33:19 T:2855267136  NOTICE: -->Python Interpreter Initialized<--
23:33:19 T:2838481728  NOTICE: -->Python Interpreter Initialized<--
23:33:19 T:3039042112  NOTICE: ES: Starting event server
23:33:19 T:3039042112   ERROR: JSONRPC Server: Failed to bind serversocket
23:33:19 T:3039042112  NOTICE: starting zeroconf publishing
23:33:19 T:2761943872  NOTICE: Thread CEventServer start, auto delete: false
23:33:19 T:2761943872  NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
23:33:19 T:2761943872  NOTICE: UDP: Listening on port 9777
23:33:19 T:2745158464  NOTICE: Thread Jobworker start, auto delete: true
23:33:19 T:2980764480  NOTICE: -->Python Interpreter Initialized<--
23:33:19 T:2736134976  NOTICE: Thread CRssReader start, auto delete: false
23:33:19 T:2796518208  NOTICE: -->Python Interpreter Initialized<--
23:33:19 T:2855267136  NOTICE: Started
23:33:19 T:2821696320  NOTICE: -->Python Interpreter Initialized<--
23:33:19 T:2813303616  NOTICE: -->Python Interpreter Initialized<--
23:33:19 T:2882534208  NOTICE: -->Python Interpreter Initialized<--
23:33:19 T:2796518208  NOTICE: 1Channel: Subscription service starting...
23:33:19 T:2796518208  NOTICE: 1Channel: Service: Auto-update disabled
23:33:19 T:2796518208  NOTICE: 1Channel: Subscription service ending...
23:33:19 T:2846874432  NOTICE: -->Python Interpreter Initialized<--
23:33:19 T:2893019968  NOTICE: -->Python Interpreter Initialized<--
23:33:19 T:2863659840  NOTICE: -->Python Interpreter Initialized<--
23:33:20 T:2863659840  NOTICE: Update Library Service starting...
23:33:20 T:2804910912  NOTICE: -->Python Interpreter Initialized<--
23:33:20 T:2863659840  NOTICE: service.libraryautoupdate: update timers
23:33:20 T:2980764480  NOTICE: Thread XBPyThread start, auto delete: false
23:33:20 T:2874141504  NOTICE: -->Python Interpreter Initialized<--
23:33:20 T:2813303616  NOTICE:  StorageServer Module loaded RUN
23:33:20 T:2813303616  NOTICE: StorageClient-1.5.0 Starting server
23:33:20 T:2813303616  NOTICE: StorageServer-1.5.0 Storage Server starting /home/travalon/.xbmc/userdata/addon_data/script.common.plugin.cache/commoncache.db
23:33:20 T:2893019968  NOTICE: Thread CFileCache start, auto delete: false
23:33:20 T:2863659840  NOTICE: service.libraryautoupdate: Update Video Library
23:33:20 T:2830089024  NOTICE: Artwork Downloader: ## Service - Run at startup: False
23:33:20 T:2830089024  NOTICE: Artwork Downloader: ## Service - Delayed startup:  minutes
23:33:20 T:2830089024  NOTICE: Artwork Downloader: ## Service - Run as service: False
23:33:20 T:2830089024  NOTICE: Artwork Downloader: ## Service - Time: :00
23:33:20 T:2893019968  NOTICE: Thread CVideoInfoScanner start, auto delete: false
23:33:20 T:2893019968  NOTICE: VideoInfoScanner: Starting scan ..
23:33:20 T:2855267136   ERROR: Traceback (most recent call last):
23:33:20 T:2855267136   ERROR:   File "/home/travalon/.xbmc/addons/script.video.parentalcontrols/resources/lib/parentalcontrols/service.py", line 25, in <module>
23:33:20 T:2980764480  NOTICE: -->Python Interpreter Initialized<--
23:33:20 T:2855267136   ERROR:     serviceiter.iterate()
23:33:20 T:2855267136   ERROR:   File "/home/travalon/.xbmc/addons/script.video.parentalcontrols/resources/lib/parentalcontrols/serviceiter.py", line 42, in iterate
23:33:20 T:2804910912  NOTICE: [SERVICE] 'inadyn v2.0.1': DEBUG: inadyn service disabled from settings!!!
23:33:20 T:2893019968  NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00
23:33:20 T:3039042112   ERROR: CWinSystemX11::XErrorHandler: BadDrawable (invalid Pixmap or Window parameter), type:0, serial:117, error_code:9, request_code:137 minor_code:7
23:33:20 T:3039042112   ERROR: CWinSystemX11::XErrorHandler: BadDrawable (invalid Pixmap or Window parameter), type:0, serial:118, error_code:9, request_code:137 minor_code:8
############### END LOG FILE ################
this is the first log:
Date: Thu Feb  7 21:21:33 MST 2013
XBMC Options:
Arch: i686
Kernel: Linux 3.0.0-30-generic-pae #47-Ubuntu SMP Wed Jan 2 22:57:16 UTC 2013
Release:
    Description:    Ubuntu 11.10 - XBMCbuntu
    Release:    11.10
    Codename:    oneiric
21:21:14 T:3047442736  NOTICE: -----------------------------------------------------------------------
21:21:14 T:3047442736  NOTICE: Starting XBMC (12.0 Git:fb595f2), Platform: Linux (Ubuntu 11.10 - XBMCbuntu, 3.0.0-30-generic-pae i686). Built on Jan 28 2013
21:21:14 T:3047442736  NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
21:21:14 T:3047442736  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
21:21:14 T:3047442736  NOTICE: special://masterprofile/ is mapped to: /home/travalon/.xbmc/userdata
21:21:14 T:3047442736  NOTICE: special://home/ is mapped to: /home/travalon/.xbmc
21:21:14 T:3047442736  NOTICE: special://temp/ is mapped to: /home/travalon/.xbmc/temp
21:21:14 T:3047442736  NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
21:21:14 T:3047442736  NOTICE: Local hostname: XBMCenter
21:21:14 T:3047442736  NOTICE: Log File is located: /home/travalon/.xbmc/temp/xbmc.log
21:21:16 T:3047442736   ERROR: CAESinkOSS::EnumerateDevicesEx - Failed to open mixer: /dev/mixer
21:21:17 T:3047442736  NOTICE: Enumerated ALSA devices:
21:21:17 T:3047442736  NOTICE:     Device 1
21:21:17 T:3047442736  NOTICE:         m_deviceName      : default
21:21:17 T:3047442736  NOTICE:         m_displayName     : Playback/recording through the PulseAudio sound server (default)
21:21:17 T:3047442736  NOTICE:         m_displayNameExtra:
21:21:17 T:3047442736  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
21:21:17 T:3047442736  NOTICE:         m_channels        : FL,FR,BL,BR,FC,LFE,SL,SR,UNKNOWN1,UNKNOWN2,UNKNOWN3,UNKNOWN4,UNKNOWN5,UNKNOWN6,UNKNOWN7,UNKNOWN8
21:21:17 T:3047442736  NOTICE:         m_sampleRates     : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
21:21:17 T:3047442736  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_U8
21:21:17 T:3047442736  NOTICE:     Device 2
21:21:17 T:3047442736  NOTICE:         m_deviceName      : pulse
21:21:17 T:3047442736  NOTICE:         m_displayName     : Playback/recording through the PulseAudio sound server (pulse)
21:21:17 T:3047442736  NOTICE:     Device 3
21:21:17 T:3047442736  NOTICE:         m_deviceName      : @:CARD=PCH,DEV=0
21:21:17 T:3047442736  NOTICE:         m_displayName     : HDA Intel PCH
21:21:17 T:3047442736  NOTICE:         m_displayNameExtra: ALC892 Analog
21:21:17 T:3047442736  NOTICE:         m_sampleRates     : 44100,48000,96000,192000
21:21:17 T:3047442736  NOTICE:         m_dataFormats     : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
21:21:17 T:3047442736  NOTICE:     Device 4
21:21:17 T:3047442736  NOTICE:         m_deviceName      : iec958:CARD=PCH,DEV=0
21:21:17 T:3047442736  NOTICE:         m_displayNameExtra: ALC892 Digital S/PDIF
21:21:17 T:3047442736  NOTICE:         m_deviceType      : AE_DEVTYPE_IEC958
21:21:17 T:3047442736  NOTICE:         m_sampleRates     : 32000,44100,48000,88200,96000,192000
21:21:17 T:3047442736  NOTICE:     Device 5
21:21:17 T:3047442736  NOTICE:         m_deviceName      : hdmi:CARD=PCH,DEV=0
21:21:17 T:3047442736  NOTICE:         m_displayNameExtra: HDMI #0
21:21:17 T:3047442736  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
21:21:17 T:3047442736  NOTICE:         m_sampleRates     : 32000,44100,48000,88200,96000,176400,192000
21:21:17 T:3047442736  NOTICE:     Device 6
21:21:17 T:3047442736  NOTICE:         m_deviceName      : hdmi:CARD=PCH,DEV=1
21:21:17 T:3047442736  NOTICE:         m_displayNameExtra: HDMI #1
21:21:17 T:3047442736  NOTICE: load settings...
21:21:17 T:3047442736  NOTICE: special://profile/ is mapped to: special://masterprofile/
21:21:17 T:3047442736  NOTICE: loading special://masterprofile/guisettings.xml
21:21:21 T:3047442736  NOTICE: Getting hardware information now...
21:21:21 T:3047442736  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
21:21:21 T:3047442736  NOTICE: Loaded playercorefactory configuration
21:21:21 T:3047442736  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
21:21:21 T:3047442736  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
21:21:21 T:3047442736  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
21:21:21 T:3047442736  NOTICE: Loaded settings file from special://profile/advancedsettings.xml
21:21:21 T:3047442736  NOTICE: Contents of special://profile/advancedsettings.xml are...
                                            <advancedsettings>
                                              <samba>
                                              </samba>
                                              <network>
                                              </network>
                                            </advancedsettings>
21:21:21 T:3047442736  NOTICE: Default DVD Player: dvdplayer
21:21:21 T:3047442736  NOTICE: Default Video Player: dvdplayer
21:21:21 T:3047442736  NOTICE: Default Audio Player: paplayer
21:21:21 T:3047442736  NOTICE: Disabled debug logging due to GUI setting. Level 0.
21:21:21 T:3047442736  NOTICE: Log level changed to 0
21:21:21 T:3047442736  NOTICE: Loading media sources from special://masterprofile/sources.xml
21:21:21 T:3041749872  NOTICE: Thread CSoftAE start, auto delete: false
21:21:21 T:3047442736  NOTICE: Running database version Addons15
21:21:21 T:3047442736 WARNING: CreateFile, error 20 opening file </home/travalon/.xbmc/addons/parental-controls-settings.txt/addon.xml>, flags:800, mode:124.
21:21:22 T:3031432048  NOTICE: Thread XBMC Peripherals start, auto delete: false
21:21:22 T:3047442736  NOTICE: Setup SDL
21:21:22 T:3047442736  NOTICE: Checking resolution 16
21:21:23 T:3047442736  NOTICE: Using visual 0x22
21:21:23 T:3047442736  NOTICE: CRenderSystemGL::CheckOpenGLQuirks - unable to parse mesa version string
21:21:23 T:3047442736  NOTICE: GL_VENDOR = Tungsten Graphics, Inc
21:21:23 T:3047442736  NOTICE: GL_RENDERER = Mesa DRI Intel(R) Sandybridge Desktop x86/MMX/SSE2
21:21:23 T:3047442736  NOTICE: GL_VERSION = 2.1 Mesa 7.11
21:21:23 T:3047442736  NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.20
21:21:23 T:3047442736  NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_logic_op GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_3DFX_texture_compression_FXT1 GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_
texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_NV_vertex_program GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_ATI_envmap_bumpmap GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_NV_vertex_program1_1 GL_APPLE_client_storage GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_MESA_ycbcr_texture GL_ARB_depth_clamp GL_ARB_
fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_rectangle GL_EXT_pixel_buffer_object GL_EXT_texture_compression_rgtc GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_APPLE_object_purgeable GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_EXT_draw_buffers2 GL_EXT_gpu_program_parameters GL_EXT_texture_env_combine GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_ARB_copy_buffer GL_ARB_half_float_vertex GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_separate_shader_objects GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_
21:21:23 T:3047442736   ERROR: GLX: Same window as before, refreshing context
21:21:23 T:3047442736  NOTICE: Running database version Addons15
21:21:23 T:3047442736  NOTICE: Running database version ViewModes4
21:21:23 T:3047442736  NOTICE: Old database found - updating from version 6 to 13
21:21:23 T:3047442736  NOTICE: Attempting to update the database Textures13 from version 6 to 13
21:21:23 T:3047442736  NOTICE: Old database found - updating from version 18 to 32
21:21:23 T:3047442736  NOTICE: Attempting to update the database MyMusic32 from version 18 to 32
21:21:24 T:3047442736  NOTICE: Old database found - updating from version 60 to 75
21:21:24 T:3047442736  NOTICE: Attempting to update the database MyVideos75 from version 60 to 75
21:21:31 T:3047442736  NOTICE: start dvd mediatype detection
21:21:31 T:3047442736  NOTICE: initializing playlistplayer
21:21:31 T:3047442736  NOTICE: DONE initializing playlistplayer
21:21:31 T:3032578928  NOTICE: Thread CDetectDVDMedia start, auto delete: false
21:21:31 T:2884598640  NOTICE: Thread XBPyThread start, auto delete: false
21:21:31 T:3047442736  NOTICE: Previous line repeats 12 times.
21:21:31 T:3047442736  NOTICE: initialize done
21:21:31 T:3047442736  NOTICE: Running the application...
21:21:31 T:2781870960  NOTICE: -->Python Interpreter Initialized<--
21:21:31 T:2755656560  NOTICE: Thread Jobworker start, auto delete: true
21:21:31 T:3047442736  NOTICE: ES: Starting event server
21:21:31 T:2747263856  NOTICE: Thread CEventServer start, auto delete: false
21:21:31 T:2747263856  NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
21:21:31 T:2747263856  NOTICE: UDP: Listening on port 9777
21:21:31 T:2738871152  NOTICE: Thread CTCPServer start, auto delete: false
21:21:31 T:3047442736  NOTICE: starting zeroconf publishing
21:21:31 T:2722085744  NOTICE: Thread Jobworker start, auto delete: true
21:21:31 T:2817452912  NOTICE: -->Python Interpreter Initialized<--
21:21:31 T:2977143664  NOTICE: Thread CRssReader start, auto delete: false
21:21:31 T:2825845616  NOTICE: -->Python Interpreter Initialized<--
21:21:31 T:2884598640  NOTICE: -->Python Interpreter Initialized<--
21:21:31 T:2859420528  NOTICE: -->Python Interpreter Initialized<--
21:21:31 T:2809060208  NOTICE: -->Python Interpreter Initialized<--
21:21:31 T:2867813232  NOTICE: -->Python Interpreter Initialized<--
21:21:31 T:2781870960  NOTICE: 1Channel: Subscription service starting...
21:21:31 T:2781870960  NOTICE: 1Channel: Service: Auto-update disabled
21:21:31 T:2781870960  NOTICE: 1Channel: Subscription service ending...
21:21:31 T:2792274800  NOTICE: -->Python Interpreter Initialized<--
21:21:31 T:2851023728  NOTICE: -->Python Interpreter Initialized<--
21:21:31 T:2842631024  NOTICE: -->Python Interpreter Initialized<--
21:21:31 T:2834238320  NOTICE: -->Python Interpreter Initialized<--
21:21:31 T:2876205936  NOTICE: -->Python Interpreter Initialized<--
21:21:31 T:2800667504  NOTICE: -->Python Interpreter Initialized<--
21:21:32 T:2859420528  NOTICE: Settings changed: False
21:21:32 T:2884598640  NOTICE: Thread XBPyThread start, auto delete: false
21:21:32 T:2851023728  NOTICE: Update Library Service starting...
21:21:32 T:2781870960  NOTICE: Thread CFileCache start, auto delete: false
21:21:32 T:2842631024  NOTICE: Started
21:21:32 T:2851023728  NOTICE: service.libraryautoupdate: update timers
21:21:32 T:2800667504  NOTICE:  StorageServer Module loaded RUN
21:21:32 T:2800667504  NOTICE: StorageClient-1.5.0 Starting server
21:21:32 T:2800667504  NOTICE: StorageServer-1.5.0 Storage Server starting /home/travalon/.xbmc/userdata/addon_data/script.common.plugin.cache/commoncache.db
21:21:32 T:2859420528  NOTICE: Invoking URL: http://api.yousee.tv/rest/tvguide/channels/format/json
21:21:32 T:2817452912  NOTICE: Artwork Downloader: ## Service - Run at startup: False
21:21:32 T:2817452912  NOTICE: Artwork Downloader: ## Service - Delayed startup:  minutes
21:21:32 T:2817452912  NOTICE: Artwork Downloader: ## Service - Run as service: False
21:21:32 T:2817452912  NOTICE: Artwork Downloader: ## Service - Time: :00
21:21:32 T:2884598640  NOTICE: -->Python Interpreter Initialized<--
21:21:32 T:2851023728  NOTICE: service.libraryautoupdate: Update Video Library
21:21:32 T:2792274800  NOTICE: [SERVICE] 'inadyn v2.0.1': DEBUG: inadyn service disabled from settings!!!
21:21:32 T:2834238320  NOTICE: Thread CVideoInfoScanner start, auto delete: false
21:21:33 T:3031432048  NOTICE: Thread CFileCache start, auto delete: false
############ END XBMC CRASH LOG #############
I don't know if it matters but 1 time sudo xbmc got me in for a short while and all my addons seemed to have disappeared. I marked all upgrades and waited 30 mins for package mgr to finish but it didn't help. Apparently I upgraded to 12.04 before I was ready hence the difference between the logs.
Next time use pastebin.com for crashlogs (see forum rules)
sorry about pastebin. I reinstalled xbmc and it fixed the problem what ever it was. I tried to delete the thread but I guess "You do not have permission to access this page. This could be because of one of the following reasons: " 1,2,3,4. so if a mod could do it thanks.
