2013-02-08, 14:44
Hi.
Some french users have build smart playlists to separate animated movies from regular movies.
And when they create the smart playlist, they call it Animés.
But XBMC is not able to display the content of such smart playlist and ERROR are written in log file :
By simply changing smart playlist name from <name>Animés</name> to <name>Animes</name> fix the problem.
So this is a work around but does XBMC can handle properly accented characters in smart playlist name ?
<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
<smartplaylist type="movies">
<name>Animés</name>
<match>all</match>
<rule field="path" operator="contains">
<value>Dessins</value>
</rule>
</smartplaylist>
13:14:40 T:876 ERROR: XFILE::CDirectory::GetDirectory - Error getting special://profile/playlists/video/Animés.xsp
13:14:40 T:876 ERROR: CGUIMediaWindow::GetDirectory(special://profile/playlists/video/Animés.xsp) failed
13:14:40 T:876 ERROR: Error loading Smart playlist (failed to parse xml: Error reading end tag.)
