Full Version: No audio Nexus 10 and Frodo RC
HI there.
I just installed the RC version of Frodo on my Samsung Nexus 10 running 4.2.1. I have great video but zero audio. I am aware that xbmc has it's own volume in addition to my device. I hear navigation sounds as I move through the xbmc GUI but no audio from any movie I play. All formats of video appear to play awesome but no audio. Any ideas?
Thank-you!
-J
I installed the last test build with hardware accelerated videos and audio runs without any problem, even DTS tracks.
Maybe you should try the final frodo release ??
I had downloaded the version on the xbmc DL page. Is that not the most current release for 12.0?
It should.
Here's the link:
http://mirrors.xbmc.org/releases/android...bi-v7a.apk
Otherwise, you can try this one, its works pretty well on my nexus 10
http://mirrors.xbmc.org/test-builds/andr...bi-v7a.apk
Thanks brother! Not sure what the difference was from my RC to the link but that fixed the issue. I just uninstalled the old one and installed the new one, then magic.
My Nexus 10 is now a go with Frodo!
-J
