Full Version: Activating info action for recent / random items - possible?
Greetings,
For recent / random items that sourced from the skin widgets service etc, is it possible to access the info for that title (i.e. dialogvideoinfo.xml)?
I've tried <onclick>action(info)</onclick> with no luck. Any suggestions?
Cheers as always.
No, theres alot of infolabels available you can create a small popup with info. I had one that allowed either play movie or trailer. But directly link to dialogvideoinfo.xml, no...
Thanks mcborzu, sensible suggestion.
Adding a route to dialogvideoinfo.xml would be preferable though (there's enough xml to manage with skins as it is!) If others support this, I'll put a feature request in.
(2013-02-09, 21:59)thedeadman Wrote: [ -> ]Thanks mcborzu, sensible suggestion.
+1
Ideally I'd like to be able to use Select / Play to play item and 'I' (Info) to open videoinfo / album tracks
I requested this while ago in Skin Widgets thread but nothing came of it...
http://forum.xbmc.org/showthread.php?tid...pid1273687
http://forum.xbmc.org/showthread.php?tid...pid1273730
Could be possible using a script, that would require to code the info screen for that respective script, similar to the info screen in global search script by ronie.
