xbmc crashes when I try viewing a channel that has bad reception. I know I should set it up correctly (with tvheadend monitoring signal quality), however xbmc shouldn't crash.
xbmc log here :
http://pastebin.ca/2311954
Seems for me tvheadend also crashes
Nope, it doesn't. Can trigger a crash also by quickly switching channels. Still only happens at random.
if you search the forum you'll find that this was reported several times (and there were some - now closed, since this "wasn't reproducible" ;-) - tickets in Git) .. I'm using Eden and I have the same problems; but now Frodo is under active development, so I hope that this is cleared .. I couldn't see, which version of XBMC do you use ..
At least I can confirm this bug for Eden and - you're right - it's an XBMC bug; tvheadend is not affected .. xbmc seems to have (in Eden) a problem if a stream is broken, independently if the stream is provided by tv backend or from another source - I get the behaviour often too if a do a fast forward >x8 with hd material ..
But now my wife learned how to kill a process on console :-)
Greetz
LastCoder
Same here, i'm running Frodo. It is definitely xbmc bug.
Sorry, forgot to mention it, I am using Frodo under Gentoo.
Quote:But now my wife learned how to kill a process on console :-)
Yeah, I start xbmc through a script, which now monitors whether it is running, and restarts it if necessary. Couldn't educate anyone on how to do it... Apart from this, Frodo is awesome.
Same issue here, I can also crash it browsing the EPG as well, with debugging turned on it shows that CPU usage hits 335% (Quad core CPU) with only EPG on screen. After posting the debug/crash files Opdenkamp said it was the Video card drivers (AMD HD6700) causing the crash for the EPG problem wonder if its connected somehow?? I must admit its starting get a little annoying. Esp when it crashs FF a recorded TV prog
(2013-02-23, 02:21)the_mouse Wrote: [ -> ]Same issue here ... After posting the debug/crash files Opdenkamp said it was the Video card drivers (AMD HD6700) causing the crash ...
Same problems with NVidia's proprietary drivers, nouveau and intel hd graphics ...
Greetz
LastCoder
btw. tried with frodo a HD livetv stream via 11b/g WLAN (with max of 54 MBits) - it simulates a bad signal very accurate
Just adding a me too on this.
$ xbmc --version
XBMC Media Center 14.0-ALPHA1 Git:dacb585
Copyright © 2005-2013 Team XBMC -
http://xbmc.org
