Full Version: low resolution thumbs on widgets?
Somehow the thumbs on the widgets are low resolution or bad resize here.
http://i.imgur.com/4jGWBTX.jpg
http://i.imgur.com/RlSdfoC.jpg
Is this expected or did I setup something wrong?
1920x1080, frodo (dsplayer), Skin Github from 8.2.2013, win7
I have <useddsfanart>true</useddsfanart> in advancedconfig since eden...
And the missing infos on the second screenshot, this happens sometimes?
When I look in the info screen of the ep all is fine.
When I reopen the the item in the widget it shows the information too.
thanks
I still have this issue. Does no one else have this, or does no one care? Smile
Using Frodo (DSPlayer Version) with latest git hub aeon nox.
On the homescreen the thumbnail on the "last episodes" widget:
On the episodes list:
The original thumbnail:
The thumbnail-file is not in the video folder, so as far as I understand it is auto generated on the client xbmc instance and put there in the cache folder.
The thumbnail is generated with a size of 360x202. I don't know where it gets this size.
The video itself is 720p.
Now the thumbnail in the episode list is something around 380x214.
The thumbnail on the startpage is cutted because of the other aspect rati. It is around 380x326.
Now the advanced config tells http://wiki.xbmc.org/?title=advancedsett...mageres.3E that the default for imageres is 720.
This should only works for fanarts or something that gets resized before creating the cached version.
So nothing for the small autocreated thumbnails.
Is there a known way to set a higher size for the autocreated thumbnails?
This could give better looking thumbs on the widget.
