Please I need to configure this remote:
http://www.amazon.com/Wireless-USB-Remot...d_sim_pc_1
No matter By EventGhost or keyboard.xml
I can't find any plugin for EventGhost related to this remote
I can't use the volume buttons inside the XBMC it only work for the windows volume
also I can't use the 4 colored buttons
Or edit the power button to be sleep
.....etc
Please Help.
And Sorry If I put this thread in the wrong place.
Just wanted to let you know that I'm the same boat. I posted a couple weeks ago for help mapping my volume keys (they only work on Windows system volume). I'll let you know if somebody points me in the right direction on my post.
I don't know why this ***** people won't help !!!!
I got the solution and I will share it :
FOR THE VOLUME:
Press Windows-R and in the Run dialog type:
notepad "%APPDATA%\XBMC\userdata\keymaps\appcommand.xml"
Click OK, and when you're prompted to create a new file answer Yes. Copy and paste the following into Notepad:
<keymap>
<global>
<appcommand>
<volume_mute>Mute</volume_mute>
<volume_down>VolumeDown</volume_down>
<volume_up>VolumeUp</volume_up>
</appcommand>
</global>
</keymap>
Close Notepad and save the changes.
FOR THE 4 COLORED KEYS:
notepad "%APPDATA%\XBMC\userdata\keymaps\keyboard.xml"
<!--Template XBMC keyboard file-->
<keymap>
<global>
<keyboard>
<one mod="ctrl,alt">XBMC.ActivateWindow(MyMusic)</one> <!-- Green -->
<two mod="ctrl,alt">XBMC.ActivateWindow(MyVideos)</two> <!-- Orange -->
<three mod="ctrl,alt">XBMC.ActivateWindow(MyPictures)</three> <!-- Blue -->
<four mod="ctrl,alt">XBMC.ActivateWindow(Home)</four> <!-- Yellow -->
</keyboard>
</global>
</keymap>
Restart your XBMC
please add this to
http://wiki.xbmc.org/index.php?title=Rem...ol_Reviews
Great job osamy!... Will use it if I buy the same remote
