Full Version: TV Show Naming Issue
Hello All,
First apologies if this topic has ben raised before. I have searched the forum/wiki and found nothing to help.
I have a tv show (Terra Nova).
The issue is the first file which is a double episode and when scraped it's seen as episode 1 only and not episodes 1 & 2.
The next file is episode 3, then 4 and so on.
However when scraped, the files are seen as ep2, ep3, ep4 etc.
No matter how the first double episode file is named (1x1-2, s01ep1ep2 etc) it is still seen as the first episode only.
My question is, with single file double episodes, is there a way for it to be seen as episodes 1 & 2 and not one episode?
I'm running Frodo using skin confluence
I really hope this makes sense.
Thanbks for your help.
i had to actually split a video ( One Off ) for mine to show up .
using mkvmerge
what file type is it ? i assume its not an iso as you said the other shows are getting scraped
http://wiki.xbmc.org/index.php?title=Vid...t_episodes
this worked for me with my ISO of a tv show
as it showed, but i never got the epbookmark to work.
IMHO , if its one of those rare occurances, id use the merge if the tv show " fades to black and says " to be continued"
heheh
GL , fun show.
Name it something like:
showname.s01e01e02.<ext>
See the wiki section posted in the previous post regarding multi-part episodes.
Also, go to thetvdb.com and pull up the show and look at how the episode order is setup over there to make sure it matches what you are expecting.
