Full Version: Disable up arrow and folder
When selecting Movies or TV Shows, it always defaults to an empty folder with the up/return arrow in the folder. Also there is the default background. Is it possible to hide this folder so that you only get your Movies and not the Return folder?
If not, then how can I change the background for that folder. As soon as you scroll to a movie the background displays the Fanart as normal
Cheers
xbmc setting: "show parent folder items"
Thanks Phil. Just one other question. All my movie are HD, so when in Showcase view, is it possible to change the Movie Set box from a dvd case to a Bluray case?
Cheers
Thanks Phil
