2013-02-12, 00:31
Hello,
i am using tvheadend as backend an having 2 satellites, you can imagine how many channels this are. I really like tvheadend, but not the channel and group configuration and so on. The group management within xbmc has no option to filter for a channel and add it to a specific group. Therefore i decided to add some functions to the contextmenu in the channelswindow and channelsOSD. In the channelswindow you can now for example filter for a specific channel in AllTvChannel group an add it to a group which you can select from a list whichs shows up. Furthermore you can select a group from a list and switch directly to it without cycling through all the channel groups. The channelsOSD has now a contextmenu, where you can select a specific group from a list you want to change to or the info for the selected channel.
you can check it out on github.
https://github.com/tBubus/xbmc
here some screenshots...
https://www.dropbox.com/s/e4h50bztsu9lu7...xtMenu.png
https://www.dropbox.com/s/yrqgk5e0oxo5crp/GroupList.png
