2015-10-22, 04:51
I have tried this addon on my raspbmc and windows htpc and neither work. The videos populate properly but clicking any video results in no playback. Even the free videos don't load
(2015-10-22, 04:51)Likea Boss Wrote: [ -> ]I have tried this addon on my raspbmc and windows htpc and neither work. The videos populate properly but clicking any video results in no playback. Even the free videos don't loadHaven't got any rpi to try but works on all devices i have tested so far..i got intel nuc win 10..intel nuc openelec on usb 3.0 stick..M8N, M8, rk3188 tv box..MXIII 2G/8G..FIRE STICK..FIRE TV BOX..
(2015-10-22, 07:57)kabise70 Wrote: [ -> ]i think this addon is not working on rp , but on widows it should be working . Try to check your addon credential.
regards,
kabise
(2015-10-17, 09:03)mytfc Wrote: [ -> ]I'm running Windows 10 and TFC.tv addon works. I use this to test scripts before applying it on my RPISir,
Boss Todits, thank you so much for your add-on. Really really useful specially for Pinoys outside Pinas
Some modifications I made on my Kodi:
1) Switched my Kodi background to my own TFC Background done in Photoshop - very Proud of TFC
2) Created favourites: The idea is for me to watch the TFC shows without having to keep on having my remote on my side
Live TFC - a playlist simulating the schedule of shows in Pinas. Example: UKG to Banana Nite.
Everyday, the playlist adjusts to the new episodes available in TFC
TFC News - a playlist of TFC News I like
TFC Drama - a playlist of current Drama series
TFC Fun - Variety, Talk, abd Comedy Shows
On-Demand - Link to TFC.tv add on
3) Fixed my Resolution to just SD
Currently HD is causing buffering while watching its annoying my wife
Our Broadband is also not unlimited, i like to use as much less data
Iniisip ko sana may Marathon option. Like if you plan to watch previous series and then continue where I left. Medyo tedious mag scroll from the very start kung yung pinapanood mo for example last year na series pa.
Current issues:
1. I find it hard to look for Kodi API to find the marker (which episodes I completely watched, and offset of those I have not completed)
2. Audio is getting out of sync after playing the 3rd or further in my playlist - current work around is to pause for few seconds
I just played around with Add-ons last week, I have 1 day to learn Kodi and Python and nag ienjoy ako
(2015-10-26, 12:25)romy4321 Wrote: [ -> ](2015-10-17, 09:03)mytfc Wrote: [ -> ]I'm running Windows 10 and TFC.tv addon works. I use this to test scripts before applying it on my RPISir,
Current issues:
I am using a wireless 3g router and bandwith is limited, can you guide me how to fixed resolution just to SD
thanks in advance
(2015-10-27, 11:36)romy4321 Wrote: [ -> ]@ mytfc
sir,
am using amazon firetv(first generation) and windows pc
my email add is [email protected]
thanks
(2015-10-27, 13:24)mytfc Wrote: [ -> ]Sir,(2015-10-27, 11:36)romy4321 Wrote: [ -> ]@ mytfc
sir,
thanks
Sent you the email just now
(2015-10-27, 19:22)markgilndavid05 Wrote: [ -> ]I am having issues right now with the add-on. I have Kodi Isengard stable version installed in my Amazon fire TV gen1, and the tfc.tv addon is not working since yesterday.
Do I need to update to Isengard- RC3 or even Jarvis? I will appreciate your prompt response. Thanks
