Full Version: [RELEASE] TFC.tv (Filipino) Video Addon Available
Hello - I added the zip file thru file manager. Then went to "install from zip file", clicked on the plugin, 2 folders appear, one is "lib" and the other is "resources". i clicked on both but nothing happens. Am I missing or doing smoething wrong? Thanks!
(2016-11-22, 09:07)nosaltnsugarpls Wrote: [ -> ]Hello - I added the zip file thru file manager. Then went to "install from zip file", clicked on the plugin, 2 folders appear, one is "lib" and the other is "resources". i clicked on both but nothing happens. Am I missing or doing smoething wrong? Thanks!
You have to select the zip file. Maybe you selected the extracted folder.
Great job cmik, it works on my Android TV! The Shows, News, and Movies functioning perfectly now. However the Live category for ANC and DZMM doesn't show up. Any chance of including it? Thanks for reviving this wonderful addon for our Kababayans.
(2016-11-22, 18:55)jnc27 Wrote: [ -> ]
Hi jnc27 - Thanks for your response. I did select the zip file, but nothing happens. It just goes to the two folders, lib & resources.
Is it correct that i added the add on thru file manager?
(2016-11-22, 20:28)musicgeek Wrote: [ -> ]Great job cmik, it works on my Android TV! The Shows, News, and Movies functioning perfectly now. However the Live category for ANC and DZMM doesn't show up. Any chance of including it? Thanks for reviving this wonderful addon for our Kababayans.
Hi musicgeek - How did you add it on your android tv? I have a Sony android tv and i'm having a hard time making this work Sad Can you let me know what repo can i find this add on? Or zip file? Or how to add it?
Hi musicgeek!
Many thanks! Good to hear that it's working for you.
About ANC and DZMM, I don't use TFC "Live" streams on my version of TFC.tv addon so I haven't noticed it. But I will try to add them. I will have to retrieve the channels from the website because they aren't on Android app and are not available also from JSON webservices.
There was also a bug in Movie section playback (we had an error when choosing a movie) but I already fixed it (see addon version below).
I have some free time so I worked a little on continuing enhancing this addon (even if I'm new at Python programmation) Big Grin until Todits returns Wink
0.0.47 https://dl.dropboxusercontent.com/u/9533...0.0.47.zip
Fixed error on movie section playback
0.0.46 https://dl.dropboxusercontent.com/u/9533...0.0.46.zip
Added most loved shows list
Added celebrity list
0.0.45 https://dl.dropboxusercontent.com/u/9533...0.0.45.zip
Fixed missing thumbnails and fanarts
Added 'My Account' in main menu
Added view to account information, entitlements and transactions
Added TFC background for addon
(2016-11-23, 02:55)cmik Wrote: [ -> ]Hi musicgeek!
Hi cmik, glad to know you're continuosly working on this addon that todits has started. Smile
(2016-11-23, 01:39)nosaltnsugarpls Wrote: [ -> ]Hi musicgeek - How did you add it on your android tv? I have a Sony android tv and i'm having a hard time making this work Sad Can you let me know what repo can i find this add on? Or zip file? Or how to add it?
Hi nosaltnsugarpls. Just download the latest zip file provided by cmik and goto your kodi app, under Settings > Addons > Install from Zip File. When installed successfully, it will automatically appear in your Videos > Addon list. You may click on it and viola! Enjoy the shows! Smile
hi guys i just want to ask how can i install the last update on libreelec, how can i put the zip file on my tv box with libreelec 7.2.7
Hi musicgeek!
hi cmik.. great job! we're really thankful that you are continuing todits work..
and now maybe a helpful feature Smile what about "Recently Added" list?
I know a little about programming and I'm interested in future implementations. So, when I find the time I can look in todits original code (.41) and your adaptation..
Thanks again!
br
(2016-11-23, 03:54)musicgeek Wrote: [ -> ]
Thanks musicgeek! It's now working for me. Smile
Thanks cmik for this update!!!! Smile
Hi musicgeek!
Your great cmik!some people i know outside uk who have their tfc.tv add on not working on their country of origin now works..thank u again...i hope todits will be back soon or maybe you can work together to make this addon great..thank u again for your work..
Hi musicgeek!
Here are new version where I added the Live section. But unfortunately, I added only the featured live streams (3) from http://beta.tfc.tv/category/live. Maybe in a future version I will add the other live streams but it will require to login to beta.tfc.tv. Actually, we only log in to tfc.tv to use JSON webservices. But if we also log in to beta.tfc.tv, TFC will count it as 2 connected users with the same account which I would like to avoid knowing that we have a limited connection number at a time.
Regards
(2016-11-23, 12:14)jnc27 Wrote: [ -> ]
Hi musicgeek!
Thanks again!
br
Hi BR!
Many thanks!
Yes, I think also that we all need a "Recently Added" list. Wink
I have made some modifications by implementing TFC's homepage shows sections (http://beta.tfc.tv/). So we have now a "Featured", "Trending Now", "Latest Show Episodes" list and others also as "With English Subtitles", "Healthy Lifestyle" like TFC website. I hope it will meet the need.
Thanks in advance for your feebacks!
Regards,
0.0.49 https://dl.dropboxusercontent.com/u/9533...0.0.49.zip
Moved Entertainment, Movies, News and Live into 'By Category' section
Added sections from TFC homepage website http://beta.tfc.tv/ to main menu
0.0.48 https://dl.dropboxusercontent.com/u/9533...0.0.48.zip
Added TFC Live stream section (but only featured shows from website page http://beta.tfc.tv/category/live)
Awesome cmik! This is so comprehensive already. You made so many of us happy Smile Thanks a lot.
(2016-11-23, 20:59)cmik Wrote: [ -> ]
Hi musicgeek!
Regards
Thanks again!
br
Hi BR!
Many thanks!
Regards,
Just to inform cmik that live section is empty on my side i dont know why,everything else is fine?thanks for your work and update.. thak u again
On my end, the Live section does appear exactly as cmik mentioned with the featured shows- Gandang Gabi Vice, TV Patrol, and DZMM. I can't play it though using the default player. But it plays fine using 3rd party player for Android at least for DZMM.
