Having problems loading adventure time season 1 2 3 but not 4 and 5 episodes are named correctly and in the right directory Adventure Time/Season 1 they are two episode single file episodes named
Adventure.Time.S01E01E02.Slumber.Party.Panic.1080p.WEB-DL.AAC2.0.H.264-Chotab.mkv
have tried naming them different but no luck
files do show up looking in source with no info
try to find info says info unavailable
Screenshot
https://www.dropbox.com/s/4dfbvrghw9yyu3...hot001.png
Season 4 and 5 load fine
Screenshot
https://www.dropbox.com/s/pyjb561r22xo19...hot002.png
log
http://xbmclogs.com/show.php?id=35056
show info is on the tvdb
Have over 4000 shows have not seen this
after searching didnt find anything
thanks for any help you can give me
Go to the show folder in file view, bring up the context menu ('c' or right-mouse-click), select Change content, then the Settings button, and turn off DVD order. Save and refresh.
(2013-02-12, 18:42)scudlee Wrote: [ -> ]Go to the show folder in file view, bring up the context menu ('c' or right-mouse-click), select Change content, then the Settings button, and turn off DVD order. Save and refresh.
no luck just did and refreshed the show removed show and added back also
Do you have a debug log from after doing that? Because the issue is clearly that you have DVD order on, but have the files named to aired order (and those steps should have fixed that).
Alternatively you can rename the files to
DVD order, e.g.
Adventure.Time.S01E01.1E01.2.Slumber.Party.Panic.1080p.WEB-DL.AAC2.0.H.264-Chotab.mkv
(2013-02-12, 18:59)scudlee Wrote: [ -> ]Do you have a debug log from after doing that? Because the issue is clearly that you have DVD order on, but have the files named to aired order (and those steps should have fixed that).
Alternatively you can rename the files to DVD order, e.g.
New log after dvd order turned off
http://xbmclogs.com/show.php?id=35078
(2013-02-12, 19:05)Shane818 Wrote: [ -> ] (2013-02-12, 18:59)scudlee Wrote: [ -> ]Do you have a debug log from after doing that? Because the issue is clearly that you have DVD order on, but have the files named to aired order (and those steps should have fixed that).
Turned dvd order on renamed fixed but would prefer aired order like the rest of my collection
season 4 5 worked aired date dvd order on and off
In your second log, you still hadn't turned off DVD order. You can tell because the episode guides (lines 1594, 1751, 1893) all still use 1.1, 1.2, 2.1, etc. in the <epnum>'s for seasons 1-3 (Don't know why it's not for 4 and 5, maybe the DVDs just aren't out?).
Highlight the Adventure Time folder in File view, press 'c' or right-mouse-click,
In the context menu select the last option 'Change content',
In the "Set Content" dialog press the 'Settings' button,
In the "Settings - The TVDB" dialog make sure the 'Use DVD order' setting is off,
Press OK,
Press OK again,
Press 'i' to bring up the info screen,
Press Refresh, and select 'Yes' to refresh info for all episodes.
Sorry, if I went a little full-on "For Dummies" there, but there must have been a step you missed when you did it the first time (perhaps by not pressing one of the OKs, just going back).
(2013-02-12, 20:47)scudlee Wrote: [ -> ]In your second log, you still hadn't turned off DVD order. You can tell because the episode guides (lines 1594, 1751, 1893) all still use 1.1, 1.2, 2.1, etc. in the <epnum>'s for seasons 1-3 (Don't know why it's not for 4 and 5, maybe the DVDs just aren't out?).
Press OK,
Press OK again,
it worked but i did hit ok two times the first time guess it didnt stick i dont know thanks and had to export library to overwrite old data
dont know how this problem hasnt come up if it was only that setting bin like years never used dvd sort order in files
well thanks again
