2013-02-12, 18:36
Just this weekend, I updated my HTPC to Windows 8 Pro. I hoped that would be as painless as when I updated my other PC's - but no
My HTPC is running several "web-servers" - CouchPotato, Sickbeard, etc.. But it's also running a Node.js-server, which is acting as a proxy to all these other web interfaces - and this proxy is set up for port 80.
Now, when using Windows 8, the system automatically occupies port 80 for something called "http.sys" (See http://www.mikeplate.com/2011/11/06/stop...n-windows/ for more detail) - this is for .Net-apps (and others) to have a common API for serving up things.
This meant, that I could not use my Node.js-based proxy. But the above link had a solution! Just make http.sys use IPv6, and leave port 80 free on IPv4!
But now XBMC cannot connect to the Argus TV Core anymore! Here's a log of the error:
Does this mean anything to anyone?? Using both 127.0.0.1 and localhost do not work. I changed it to localhost, because it was mentioned in the article above.
Thanks in advance!
17:29:32 T:5180 ERROR: AddOnLog: ARGUS TV client: can not write to http://localhost:49943/ArgusTV/Core/Ping/52
17:29:32 T:5180 ERROR: AddOnLog: ARGUS TV client: Ping failed... No connection to Argus TV.
17:29:33 T:5180 ERROR: ADDON: Dll ARGUS TV client - Client returned bad status (6) from Create and is not usable
17:29:33 T:5180 WARNING: PVR::CPVRClients::UpdateAndInitialiseClients - failed to create add-on ARGUS TV client, status = 6
17:29:33 T:5180 WARNING: PVR::CPVRClients::UpdateAndInitialiseClients - failed to load the dll for add-on ARGUS TV client, disabling it
17:29:33 T:3920 NOTICE: Thread CAddonStatusHandler:pvr.argustv start, auto delete: true
Thanks in advance!
