2013-02-12, 20:47
Hi
Well, I've just spent the most unproductive two days trying to upgrade to Frodo on my Aleutia T1 set-top-box.
This was NOT a painless experience, and all is still not well.
1) I discovered that Crystal HD support is broken in Frodo and I needed to rebuild the Crystal HD packages
2) I discovered that the method for suspending on XBMCBuntu using a USB IR receiver is different and that took hours to get going.
3) Now when I resume, instead of going back to the resolution I had before, it goes to the first detected - that doesn't work well with stuttering and all kinds of nastiness on my TV.
So, I built what I thought was a good xorg.conf, but that toasted the whole system and I had to do a complete re-install.
All I want is 1280x720 60Hz as the only resolution available to my DVI port and the ability to suspend/resume from the remote and have it come back at that resolution.
Can it really be that difficult ?
D
D
