2013-02-12, 22:28
I just got started at skinning, only because I wanted to tinker with Navi-X controls... so I made a web UI (pure jQuery/css) that will read xml and allow drag/drop for posx/posy & resize for height/width and spit out new xml in a pre tag, as for what you see now that's all it does but I was wondering what are some key features a skinner would like to see in this?
So far on my todo list is:
Not sure how long I will be on this project, hopefully I can get enough done to at least help someone else align objects properly!
As for now it will run only if you manually input filename of xml in the html and the editor in same folder as the xml and load from file://etc
As for releasing I don't want to handle any bugs questions or concerns yet I am trying to get a few more suggestions before I get burnt out and post it and probably end up letting someone else take over
Post some requests! other than a link at this time
- Show list of all XML windows within selected folder + a quick switch to
- Displaying Images
