2013-02-14, 05:37
So when I'm in XBMC, I get sounds in the menus and in videos. I do NOT get sound in mednafen (I'm using Adv Launcher). For what its worth, I'm not getting sound in *any* emulator when I'm in XBMC, but I've only played with mednafen because I'm most comfortable with it.
Seems weird that it works no problem when I launch outside of XBMC, but kick it off in XBMC and I got nothin. Any ideas?
Architecture: i686
XBMC 12.0 Git:fb595f2
Audio Output Device: HDA Intel PCH… on HDMI
Passthrough output device: HDA Intel PCH… on HDMI
Aplay –l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC662 rev1 Analog [ALC662 rev1 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 1: ALC662 rev1 Digital [ALC662 rev1 Digital]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Mednafen CFG:
;Select sound output device.
sound.device sexyal-literal-default
;Select sound driver.
sound.driver alsa
Asounddrc:
pcm.dmixer {
type dmix
ipc_key 1024
ipc_key_add_uid false
ipc_perm 0660
slave {
pcm "hw:0,3"
rate 48000
channels 2
format S32_LE
period_time 0
period_size 1024
buffer_time 0
buffer_size 4096
pcm.!default {
type plug
slave.pcm "dmixer"
Architecture: i686
Aplay –l
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
Mednafen CFG:
sound.driver alsa
Asounddrc:
pcm.dmixer {
type dmix
ipc_key 1024
ipc_perm 0660
slave {
pcm "hw:0,3"
rate 48000
channels 2
format S32_LE
period_time 0
period_size 1024
buffer_time 0
buffer_size 4096
pcm.!default {
type plug
slave.pcm "dmixer"
