Full Version: [Workaround] Uploading avatar does not work, use URL instead
Hi, my forum avatar wont display after a new upload. I've tried several different images with various types (gif, jpg) and size was way below the 100x100 limit but in vain.
Solved - It worked using the url instead of uploading a file. I guess there are some problems with the upload function, maybe a permission problem with the upload directory?? ...
thanks for the info - need to check - it's quite possible so as we recently switched servers and also parts of the file structure/permissions
same problem here. can't upload an avatar. always getting the error "The file upload failed. Please choose a valid file and try again."
Filetype: JPG; 100x78 pixel; 7kb;
thanks for reporting the issue - it's fixed now.
