2013-09-20, 08:50
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52
2013-09-20, 10:21
(2013-09-20, 08:50)afedchin Wrote: [ -> ]You can get the EPG from online services or create it by appropriate software then store the epg on local (or network) path.i'm really stupid .. where can i must define this url? only click in gui? or somewhere in file on storage?
sorry, i have it ..
thanks for your help
2013-09-20, 12:08
afedchin: please, did you have sample for epg file? i don't know root tags and another tags which i must or may used.
my EPG file is
and m3u playlist is
where is a problem? i cant see anything in EPG
my EPG file is
<?xml version="1.0" encoding="UTF-8"?>
<tv generator-info-name="dvb-epg-gen">
<channel id="id3">
<display-name lang="cs">Ceska televize 2</display-name>
</channel>
<channel id="id4">
<display-name lang="cs">Ceska televize 24</display-name>
</channel>
<programme start="20130920021500 +0200" stop="20130920022139 +0200" channel="id3">
<title lang="cs">Chcete je?</title>
<sub-title lang="cs">Nabídka zvířat z útulku.</sub-title>
<desc lang="cs">Znakový jazyk|Zvukový popis|</desc>
<language>cs</language>
<video>
<aspect>16:9</aspect>
</video>
<audio>
<stereo>stereo</stereo>
</audio>
<subtitles type="teletext">
</subtitles>
</subtitles>
</programme>
<programme start="20130923140000 +0200" stop="20130923140500 +0200" channel="id4">
<title lang="cs">Zprávy</title>
<video>
</video>
<audio>
</audio>
</subtitles>
</programme>
<programme start="20130923140500 +0200" stop="20130923143000 +0200" channel="CT24">
<title lang="cs">Studio ČT24</title>
<desc lang="cs">Aktuální rozhovory na aktuální témata v ČR i ve světě. Možnost přerušení vysílání v důsledku přímých přenosů z významných akcí. 16:9</desc>
<video>
</video>
<audio>
</audio>
</programme>
</tv>
and m3u playlist is
#EXTM3U
#EXTINF: -1 tvg-id="id3" tvg-name="CT2" tvg-logo="003", CT2
http://192.168.97.1:4000/udp/239.1.2.2:11111
#EXTINF: -1 tvg-id="id4" tvg-name="CT24" tvg-logo="004", CT24
http://192.168.97.1:4000/udp/239.1.2.3:11111
2013-09-20, 16:32
On rpi i can't use this addon, because when i enable PVR the system is rebooted and PVR is still disabled
2013-09-21, 20:48
Is it possible to setup a special XMLTV file for radio stations?
2013-09-23, 00:03
Hi I have a small problem. I DVBviewer as PVR. And now I still have this plugin installed.
If I use IPTV but it is so that I have ONLY a channel list. Without this plugin I have many different lists. How is it? Can you help me?
2013-09-23, 01:32
(2013-09-23, 00:03)babesumitra Wrote: [ -> ]Hi I have a small problem. I DVBviewer as PVR. And now I still have this plugin installed.
This is a known issue that seems to be related to XBMC and not to IPTVSimple.
http://trac.xbmc.org/ticket/14498
With Gotham alpha build it less frequent, so you might want to try the latest build.
http://wiki.xbmc.org/index.php?title=Development_builds
2013-09-23, 01:53
Thank u, but i use OpenElec 3.20 stable (i dont think that they have Gotham alpha Versions); but many thanks for your help.
How can i make it the Tv Channel as Radio Channel; i think that then they are less problems.
Is this so ok?
#EXTM3U
#EXTINF:-1,group-title="Radio",Channel 1
http://XXXXX:XXXX@XXXXX:XXX
Is this so ok?
#EXTM3U
2013-09-23, 06:41
2013-09-23, 08:56
thanks
2013-09-24, 07:19
Has anyone ever get working genre colors in the EPG?
I've genres like these:
Is there a way to translate these genres inside the addon to work with XBMC? MediaPortal addon use a file called "genre_translation.xml".
<category lang="de">|Kulturmagazin|</category>
<category lang="de">|Nachrichten|</category>
<category lang="de">|Dokumentation|</category>
2013-09-25, 04:58
Has there been any progress on getting IPTVSmple to work with "Plugin://" streams? Really would love to get USTVNow integrated with my other live TV stations.
2013-09-25, 13:34
Hello all,
I have been reading this post with great interest.
IPTV Simple works great with Openelec (latest 3.2.0).... but Openelec is very slow compaired to Raspbmc.
Can someone guide me how to compile IPTV Simple for the Raspbmc?
I tried all the version I could find by "install from ZIP" under Raspbmc, but none of them work.
So, how can I compile a version for Rasbmc?
Thanks in advance for your help!
2013-09-25, 20:03
I think a RaspPi isn't the best choise for a HTPC with PVR. I have byself two models (256 and 512 MB) and it's all really slow (OpenELEC or RaspBMC)
2013-09-25, 20:28
I cannot play the following format into iptvsimple pvr. Is there a way to play this into iptv pvr?
#EXTM3U
#EXTINF:-1,PTV WORLD
rtmp://$OPT:rtmp-raw=rtmp://live.server4sale.com/live playpath=8090 swfUrl=http://live.server4sale.com:81/swfs/videoPlayer.swf live=1 pageUrl=http://world.ptv.com.pk/LiveStreaming.asp -C B:0 --live
#EXTM3U
