(2013-12-02, 14:17)amelendez Wrote: [ -> ]Hi everybody,
I have installed xbmc frodo with iptvSimple v1.6.1 in linux without problems. I realised that a problem exist when you change from one channel to other and I have read on the forum that this is a know issue. I have tried to update to xbmc Gotham (alpha 9) but I have several problems when I try to activate IPTVSimple... The computer freezes. I'm using IPTV Simple v1.9.2.
Which are the correct versions that I have to install in order to have this working properly?
Thank you in advance.
i think you can use iptv simple v1.8
i just upgraded to gotham (alpha10) and had to upgrade my pvr addons to versions that use api version 1.9.
for anyone having pvr-difficulties after an upgrade to the latest testing versons of xbmc, grab the pvr addon sources from
here, compile and install the needed addons manually.
Thank you for your answer thatguy7669,
I supposed that this was the sollution but I didn't find any branch or release of this version in xbmc-pvr-addons repository or in xbmc-addon-iptvsimple repository.
I ussually use cvs or svn and I'm not very familiarised with git so maybe I'm doing somethin wrong.
Maybe using gotham alpha 10 can be another option if its more stable than alpha 9...
Is there a zip file of this addon that we can use for iOS (apple tv)?
Hi to all.
I see that my question is not new, but I can't do this by myself.
This is my radio section in playlist:
#EXTINF:-1 group-title="Radio" radio="true", Radio FM
http://219.21.55.163:8000/72k.aac
#EXTINF:-1 tvg-id="radio-us-the_blitz" tvg-name="radio-us-the_blitz" tvg-logo="radio-us-the_blitz" group-title="Radio" radio="true", The Blitz
http://icy3.abacast.com/nabco-wrkzfmaac-48
But this stations are not appear in radio. What I'm doing wrong?
@Sir_Lyoshyk,
try replace section into your playlist to the following lines:
#EXTINF:-1 group-title="Radio" radio=true, Radio FM
#EXTINF:-1 tvg-id="radio-us-the_blitz" tvg-name="radio-us-the_blitz" tvg-logo="radio-us-the_blitz", The Blitz
Hi all.
I asked before for the posiblity (in settings maybe) of merge channels with the same name, that would be treated as two different sources, and if the first fails (time off) go on to the second one. As an exaple I use some channels that have two diferent streams, one of them with better quality but is not always online an the other one poor quality but more stable, after all I wan't to say merge different sources to the same channel, like others pvrs do if you have more than one tv card, and afedchin said that was in todo list.
Any progress on this?
Is imposible to do?
Congratulations for yor great addon and thanks for your work.
Hello, any news regarding the "BUG" when the IPTV simple plugin does not refresh the cached iptv.m3u.cache file?
@goibe,
It isn't possible because the addon doesn't controls playback, it just provides channels (with stream url) to the xbmc.
@kissi7,
I haven't got time enough for implement this simple feature. I'll implement this asap.
Hi Afedchin, thanks for your great addon! I use it for a long time and I've never had any problems.
(gotham alpha 9 and iptv simple 1.8.1 works fine, the new version give me "dependiences not me" error, but it's not a problem).
Now I wuold like to load a playlist storaged on my site so that I can share it with others users and upgrade it each day. I've read all the 48 pages and I know that you have already specify that this wasn't possible but maybe there are some news!? do u think it is possible in somehow?!
I think even Dhead user has already made a similar request in the past.
Thanks in advance.
last two days can`t watch channels like this (
http://149.62.176.210/udp/239.100.0.4:12...TzyRQH-1_z ) in xbmc with pvr.iptv.simple addon....i got this error...this channels are still works fine in VLC player....any solutions? maybe is a problem with user agent string?
10:07:27 T:3720 NOTICE: Thread DVDPlayer start, auto delete: false
10:07:27 T:3720 NOTICE: Creating InputStream
10:07:28 T:3720 ERROR: CCurlFile::FillBuffer - Failed: Server returned nothing (no headers, no data)(52)
10:07:28 T:3720 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
10:07:28 T:3720 ERROR: XFILE::CFileCache::Open - failed to open source <http://149.62.176.210/udp/239.100.0.4:1234?key=YdenRZe4-7ecTzyRQH-1_z>
10:07:28 T:3720 ERROR: CDVDInputStreamPVRManager::Open - error opening [http://149.62.176.210/udp/239.100.0.4:12...TzyRQH-1_z]
10:07:28 T:3720 ERROR: CDVDPlayer::OpenInputStream - error opening [pvr://channels/tv/Vsi TV programi/78.pvr]
10:07:28 T:3720 NOTICE: CDVDPlayer::OnExit()
10:07:28 T:3720 NOTICE: CDVDPlayer::OnExit() deleting input stream
Hello,
Ok, so I have an iptv service nettv plus that I use and watch over my computer. I saw some people talk about using it through xbmc. I am totally new to xbmc and was wandering if someone can help me out if that is not too much to ask for. I know I have to make a list (m3u) but I dont know how to do that :/ sorry very new. So if someone can explain to me in detail how I would go about trying this, I would appreciate any help. If not, thanks anyway
. Any info you need I can provide.
thanks
This is a suggestion to author of this My Favorite PVR,
can you make the EPG7 database in hiden folder
C:\Users\******\AppData\Roaming\XBMC\userdata\Database\epg7.db
To take the adress from epg.xml from line
<icon src="http://tv.voila.fr/images/programmes/large/2013/12/12/16521961_169_43611614.jpg" />
and put in epg7.db in tabel "epgtags" colon "sPlotOutline" and change colone name ,like in tv.guide "image_small".
I will later connect the PVR EPG that displays the images of our EPG.SF (we made some about more then 560 epg events and logo signs for europian channels)
It's a small thing, but I need for a perfect media box.
Here is picture of my PVR screen with file epg7.db
http://img59.imageshack.us/img59/8986/jj7e.png
I agree with Angelians. It would be great if we could include the <icon src="..."/> tag from the XMLTV file.
Often this tag includes the poster\cover of a movie or tv-series. So when you press Info while watching a channel or in the EPG view, your could get poster\cover art for the movie\tv show.
This would be great since there is no support for scrapers in LiveTV.
Is it somehow possible to record tv channels using this add-on?
