(2013-12-10, 18:14)ercia Wrote: [ -> ]Hi Afedchin, thanks for your great addon! I use it for a long time and I've never had any problems. (gotham alpha 9 and iptv simple 1.8.1 works fine, the new version give me "dependiences not me" error, but it's not a problem).
Now I wuold like to load a playlist storaged on my site so that I can share it with others users and upgrade it each day. I've read all the 48 pages and I know that you have already specify that this wasn't possible but maybe there are some news!? do u think it is possible in somehow?!
Sure, you can host your playlist on an any server. The addon will correctly update m3u if the server provides correct modified time of playlist.
(2013-12-13, 11:16)Bayern Wrote: [ -> ]last two days can`t watch channels like this ( http://149.62.176.210/udp/239.100.0.4:12...TzyRQH-1_z ) in xbmc with pvr.iptv.simple addon....i got this error...this channels are still works fine in VLC player....any solutions? maybe is a problem with user agent string?
This an issue of xbmc. The addon doesn't open any stream.
(2013-12-14, 14:26)Angelinas Wrote: [ -> ]This is a suggestion to author of this My Favorite PVR,
can you make the EPG7 database in hiden folder
C:\Users\******\AppData\Roaming\XBMC\userdata\Database\epg7.db
To take the adress from epg.xml from line
<icon src="http://tv.voila.fr/images/programmes/large/2013/12/12/16521961_169_43611614.jpg" />
and put in epg7.db in tabel "epgtags" colon "sPlotOutline" and change colone name ,like in tv.guide "image_small".
I will later connect the PVR EPG that displays the images of our EPG.SF (we made some about more then 560 epg events and logo signs for europian channels)
It's a small thing, but I need for a perfect media box.
Here is picture of my PVR screen with file epg7.db
http://img59.imageshack.us/img59/8986/jj7e.png
(2013-12-16, 11:22)Maniac Wrote: [ -> ]I agree with Angelians. It would be great if we could include the <icon src="..."/> tag from the XMLTV file.
Often this tag includes the poster\cover of a movie or tv-series. So when you press Info while watching a channel or in the EPG view, your could get poster\cover art for the movie\tv show.
This would be great since there is no support for scrapers in LiveTV.
All what I can do is parse <icon src="..."/> tag from the XMLTV file and set EPG parameter strIconPath, like Maniac said. I don't try this but I think that this will work.
Hi there.
Has any one noticed when watching a live multicast stream ( ether mpeg2 or mpeg4 ) the cpu usage slowly creeps up to 50% and the same happens to the network ( usage goes to 50% ) but stops there ( maybe it can just use 1 core as i have the Intel Celeron 867 which has 2 cores ).
I have checked the server i am streaming the multicast through but the network is at the same 4Mbits constant so the network is not loading the server.
I have tried the Openelec intel 3.2.4 Intel and the generic 32bit both have the same problem.
As the zotac nano is loud at above 35% cpu load this is really annoying.
If i stop and start the channel it goes down to 5-6% again an starts to creep up again.
Hello, thanks afedchin for this great addon..it's working without a prob on my android tv - gotham alpha 10..and now..anyone please can help me? i need version for 12.2 frodo on android box, i was searching and searching on internet for zip file, i found something, no luck. I'm not really a specialist in theese things, so compiling a git file etc nothing helps me..please anyone who can help thanks!
Sorry for bad english.
Greet from Slovenia
Hello, i am trying to get this to work with Apple TV, does this work with ATV2, i have it on MAC but no success getting it with the ATV anyone can help thanks
Hi, I'm a XBMC Newbie and so far I love it. I saw IPTVSimple PVR on YT and I wanit!!! I have a Minix Android and I'm a bit confused from previous posts, is there a direct addon now or do you have to still build it inside xbmc? There are some who suggested there is direct addon in XBMC but I cant find it. Sorry to be such a simpleton, but this is my first time with an android device , I have to use Python to build right? Also can someone suggest the easiest way and the most current download link to get started.
Thanks in advance.
(2013-12-18, 16:03)t0mekk Wrote: [ -> ]Hello, thanks afedchin for this great addon..it's working without a prob on my android tv - gotham alpha 10..and now..anyone please can help me? i need version for 12.2 frodo on android box, i was searching and searching on internet for zip file, i found something, no luck. I'm not really a specialist in theese things, so compiling a git file etc nothing helps me..please anyone who can help thanks!
Greet from Slovenia
For Frodo on android, please download and install Frodo 12.3 which already contains the addon. There is no possibility to install the addon from zip on android.
(2013-12-26, 14:14)asho76 Wrote: [ -> ]Hello, i am trying to get this to work with Apple TV, does this work with ATV2, i have it on MAC but no success getting it with the ATV anyone can help thanks
Same, please download and install Frodo 12.3 or latest Gotham alpha which contains the addon.
Hi everyone, I saw that a person was directed to this thread coz he wanted to play m3u file through xbmc, which I would also like to play, do you need a simpletv box or other boxes with tv sat feeds capture to play these m3u files, because I tried a few m3u files and they dont go through to live tv.
Many thanks in advance.
(2014-01-03, 01:28)chavier82 Wrote: [ -> ]Hi everyone, I saw that a person was directed to this thread coz he wanted to play m3u file through xbmc, which I would also like to play, do you need a simpletv box or other boxes with tv sat feeds capture to play these m3u files, because I tried a few m3u files and they dont go through to live tv.
Your do not need any box, just the iptv.simple pvr-addon for XBMC. There your need to confgure a .m3u file that has the streams, and if you want a .xml file that has the EPG for those channels.
iptv.simple pvr-addon is included in xbmc versions from 12.3 >
See this post on how to set up the m3u file:
http://forum.xbmc.org/showthread.php?tid...pid1339559
[/quote]
[/quote]
Cheers for the shout, only got some of the links to work, the http links worked. However all the links in the form of "rtmp://$OPT:rtmp-raw=rtmp" didn't work and most of my m3u file consisted of these links.
Thanks anyway.
(2014-01-03, 09:37)Maniac Wrote: [ -> ] (2014-01-03, 01:28)chavier82 Wrote: [ -> ]Hi everyone, I saw that a person was directed to this thread coz he wanted to play m3u file through xbmc, which I would also like to play, do you need a simpletv box or other boxes with tv sat feeds capture to play these m3u files, because I tried a few m3u files and they dont go through to live tv.
See this post on how to set up the m3u file: http://forum.xbmc.org/showthread.php?tid...pid1339559
I got the rtmp files to work and it works perfectly now. So thanks again.
Is it possible to add REGEX expression support for this addon ? also is it possible to add link to other plugings for example
#EXTM3U
#EXTIN:-1 channel name
plugin://plugin.video.youtube/channel......
Thank you
afedchin
Thanks, the base logos url feature in v1.9.3 works great.
(2014-01-07, 17:52)fouad796 Wrote: [ -> ]Is it possible to add REGEX expression support for this addon ? also is it possible to add link to other plugings for example
#EXTM3U
Thank you
It isn't possible to use special path like plugin://
(2014-01-07, 23:24)dhead Wrote: [ -> ]@afedchin
You are welcome!
v1.9.3
- added setting to disable cache m3u/epg
- added support <icon src=""/> for programme in epg
- added possibility to specify logo path as URL
- changed tvg-logo should contains full logo filename (with extention)
- changed don't try download xmltv if it doesn't load after 3 attempt.
Yay!
How do we get to show this element in a skin? Is it saved under "plotOutline" or some other property?
anything about Regex expression , is it possible in m3u ?
