Full Version: Bad EPG-behaviour with Apple Remote
Hi!
Just got me a mythTV backend to suit up my XBMC network with. Works like a charm, for most parts.
However with my Mac Mini it's quite messy with the Apple Remote.
When I'm in the EPG everything works ok, but when I'm watching a channel and want to get back to the EPG i press "back". But this stops the playback, and I wind up at the top of the EPG menu (Channel #1). So if I were watching channel 100 and want to browse further I have to start from channel 1 and browse all the way down past channel 100 again.
On the PC (Win + Linux machines) I can just press ESC, and then I get back to the EPG at the same place I was before.
Is there anything I can do about this myself?
Otherwise, for upcoming releases. Please do something about this, it really takes the edge of the otherwise good experience with XBMC frontend to mythTV. An easy solution would be just to get back to the EPG on the last viewed channel, even if you stop the playback.
//y0da
If i read your post correctly, you can try this and see if it helps.
http://forum.xbmc.org/showthread.php?tid=150022&page=3
