Full Version: Fanart on Movie & TV Homescreens
Hi all,
I just updated to Frodo & setting everything back up. The one thing that I can not seem to get working, is having the fanart I have specifically for tv and movies to display on thier relevant homescreen's. There used to work when I was on Camelot,but it's obviously a setting that I can't remember to get it working. Any help would be appreciated.
Thanks Ronie. Found the section talking about this
Important Change since Eden:
1) if you use the "Home-Movies-Fanart", "Home-Tv Shows-Fanart" or "Home-Music-Fanart" options,
those will not work out-of-the box anymore.
due to changes in XBMC, you will now need to select a custom folder containing this artwork.
you can use the artwork-organizer script to create these folders.
