2013-05-15, 13:46
2013-05-15, 15:02
(2013-05-15, 13:14)ace20022 Wrote: [ -> ]Maybe it is necessary to configure ffmpeg with "--enable-libopus" ?
For testing opus and speex, flyingrat made some osX and win32 builds: https://www.dropbox.com/sh/a7tsbe6o80rrv...x_and_opus
(2013-05-14, 22:27)sialivi Wrote: [ -> ](2013-05-14, 21:47)flyingrat Wrote: [ -> ]Hard to tell if that was from any of my old binaries or not. I'll check which versions are online...
It was with XBMCSetup-20130419-c01c97d-dx.exe
I think you have to use those builds: https://www.dropbox.com/sh/a7tsbe6o80rrv...x_and_opus
yours looks too old
2013-05-15, 15:13
Yeah and you also need "--enable-speex" and both libraries must be installed beforehand since ffmpeg configure has some header files dependencies that is being used during config otherwise you get "configure: lib not found LIBOPUS" (or similar). I think there is a helper script in that branch named "re-config-with-speex-and-opus.sh" in lib/ffmpeg that performs some of that stuff for you...
2013-05-15, 18:07
I guess I was too inattentive, sorry. Will try your script...
2013-05-15, 18:40
(2013-05-15, 18:07)ace20022 Wrote: [ -> ]I guess I was too inattentive, sorry. Will try your script...
Well, it's quite easy to miss since it's not very well documented Btw, i'm not sure i've updated the script to work with win32 but here are some hints thanks to Skixbmc: http://forum.xbmc.org/showthread.php?tid...pid1414391
2013-05-15, 21:12
(2013-05-15, 15:02)Robotica Wrote: [ -> ]I think you have to use those builds: https://www.dropbox.com/sh/a7tsbe6o80rrv...x_and_opus
yours looks too old
My mistake; that is actually the build I was using, as can be seen in the log I posted: 13.0-ALPHA3 Git:20130429-0caabba
2013-05-15, 23:49
(2013-05-15, 18:40)flyingrat Wrote: [ -> ](2013-05-15, 18:07)ace20022 Wrote: [ -> ]I guess I was too inattentive, sorry. Will try your script...
I had a brief look and gave up, I'm developing under windows; this msys stuff is no fun, at least for me
Then I tried to misuse the dlls from your build, but just got:
CDVDAudioCodecFFmpeg::Open() Unable to find codec 1330664787
line 71: pCodec = m_dllAvCodec.avcodec_find_decoder(hints.codec); # hints.codec = AV_CODEC_ID_OPUS
(2013-05-15, 15:02)Robotica Wrote: [ -> ](2013-05-15, 13:14)ace20022 Wrote: [ -> ]Maybe it is necessary to configure ffmpeg with "--enable-libopus" ?
Strange, but I can't play any media with this build:
ERROR: Win32DllLoader::Load: Failed to load ***\XBMC\system\players\dvdplayer\avcodec.dll with error 126:Das angegebene Modul wurde nicht gefunden.
2013-05-16, 07:31
(2013-05-15, 23:49)ace20022 Wrote: [ -> ](2013-05-15, 18:40)flyingrat Wrote: [ -> ](2013-05-15, 18:07)ace20022 Wrote: [ -> ]I guess I was too inattentive, sorry. Will try your script...
fromCode:CDVDAudioCodecFFmpeg::Open() Unable to find codec 1330664787
Code:line 71: pCodec = m_dllAvCodec.avcodec_find_decoder(hints.codec); # hints.codec = AV_CODEC_ID_OPUS
Code:ERROR: Win32DllLoader::Load: Failed to load ***\XBMC\system\players\dvdplayer\avcodec.dll with error 126:Das angegebene Modul wurde nicht gefunden.
If you compile ffmepg, you also have to compile the libs you needed and install them with "make install", otherwise ffmpeg won't find them.
Reg.
Fred
2013-05-16, 12:04
(2013-05-16, 07:31)Skixbmc Wrote: [ -> ]If you compile ffmepg, you also have to compile the libs you needed and install them with "make install", otherwise ffmpeg won't find them.
Reg.
Fred
Sure, I tried to avoid changing the msys environment shipped with xbmc first. Now I have done it the way you proposed and "installed" pkg-config and opus.
The test files play fine with these dlls i can upload them, if anyone is interested.
2013-05-19, 18:36
Do you planing updated FFmpeg to 1.2.1 version??
2013-05-19, 21:20
(2013-05-19, 18:36)rbej Wrote: [ -> ]Do you planing updated FFmpeg to 1.2.1 version??
As always, it depends on the needs. Any particular in 1.2.1 you're looking for?
2013-05-20, 09:19
Im looking fixed http://trac.xbmc.org/ticket/14319
2013-05-20, 09:27
(2013-05-20, 09:19)rbej Wrote: [ -> ]Im looking fixed http://trac.xbmc.org/ticket/14319
Ok, that seems like a reasonable argument! Btw, do you get the same result with ffplay on rpi?
2013-05-20, 12:50
Are you sure ffmpeg 1.2.1 fixes the issue?
2013-05-20, 18:54
Not fixes. I compile two hours ago Xbmc with 1.2.1 and bug still exist. I try 0.10.7 (04.10.2013) and everything is ok.
