2013-02-15, 23:34
Greetings,
Sometimes (a lot of times) when I crop an image the result is a very fine white line around the outside edge (not always all edges) of the image. I have used numerous image editors, and they all do it to some degree. Can someone tell me why this is so, and if it can be resolved.
Further, I have noticed that other downloaded images (ones I haven't created) can also have this effect - as though the crop leaves 1/2 a pixel cut mark or something.
I use Photodraw (old...but I know it very well). I've used Photoshop, Photoshop Elements, PaintShop Pro, IRFranView and several others and they all do it to some small degree.
The only way I can fix it is to clone the edge right around the image - a slow and time consuming process.
Thx.
PS...a little off topic, but can someone recommend an image editor that can replace Photodraw (which is both and image and vector editing/creating programme). AND...one that can leave text in a format that can be edited (unlike some which flatten the text once mods have been made and then it can no longer be changed).
Thx.
