2013-02-16, 02:40
Hello, im getting an error while trying to play a youtube video, i got the playback error "couldn't locate video url" whit any link of youtube video.
This is my xbmc log.
http://www.xbmclogs.com/show.php?id=35837
Thanks a lot... Sorry for my bad english tho
SOLVED
this worked for me...
SOLVED
(2013-02-14, 13:35)Mossy Wrote: [ -> ]Quick hack that works for me, replace YouTubePlayer.py with this: https://www.dropbox.com/l/GBKQUmxrRnoOBGFB - you can download this and copy it into your plugin.video.youtube folder.
Alternatively you can install one of the following plugins, which is the regular youtube plugin with the fix applied (go to System | Addons | Install from zip and select the downloaded zip file):
Eden (XBMC 11) plugin zip: https://www.dropbox.com/l/SrdosdpacjeyvDgd
Frodo (XBMC 12) plugin zip: https://www.dropbox.com/l/axITMmdkQzSpIuDD
Update: ... or you can use rc42's patch below...
