Full Version: Help : Manual Install Works but install through XBMC does not
Hello,
This is my first add-on (disclaimer I am not most experienced programmer) that being said I have made an add-on that works if I manual install it. But if I zip it up and try and install it through XBMC I get "Add-on Does not have the correct structure". Just can't figure out why it works only installs manually (copying in addons folder) I want to be able to distribute it at some point so a manual install only is not an option
I am testing this on the latest release of Raspbmc
Please find my add-on here http://dev1.tommyz.tk/plugin.music.mixta...-0.0.1.zip
Any input will be appreciated.
any ideas?
PHP Code:
fileaddon.py
import urllib2
import re
from xbmcswift2 import Plugin
from BeautifulSoup import BeautifulSoup
plugin
Plugin()
mixtapepage plugin.get_storage('mixtapepage'TTL=120)
def parse_categories():
page urllib2.urlopen("http://www.mixtapepage.com/index.php")
soup BeautifulSoup(page)
categories soup.findAll('li')
    return
categories
def remove_dups
(seqidfun=None):
# order preserving
if idfun is None:
def idfun(x): return x
    seen
result = []
    for
item in seq:
marker idfun(item)
        if
marker in seen:continue
seen[marker] = 1
        result
.append(item)
    return
result
def parse_category_titles
(soup):
titles soup.findAll('td',attrs={'width' :'70%'})
    return
titles
def parse_category_links
(soup):
links soup.findAll('a',href=True)
cleanLinks =[]
    for
a in links:
        if
a['href'].startswith("played.php?id="):
cleanLinks.append(a['href'])
cleanLinks remove_dups(cleanLinks)
    return
cleanLinks
def part_thumbnails
(soup):
images soup.findAll('img',src=True)
imgsrc = []
sep ="&sizex"
for img in images:
        if
img['src'].startswith("thumb"):
img['src'] = img['src'].split(sep1)[0]
img['src'] = img['src'].replace("thumb.php?file=","")
imgsrc.append(img['src'])
    return
imgsrc
def numberof_pages
(soup):
paginator soup.findAll('option')
sep1 "\">"
sep2 ="value=\""
temp = []
remove_dups(paginator)
    for
page in paginator:
        if
str(page).startswith("<option value=\""):
popper page
            popper
str(popper).split(sep11)[0]
popper popper.split(sep21)[1]
popper popper.replace("\" selected=\"selected","")
popper popper.replace("featured.php","")
            if
popper.startswith("index.php?") == False:
temp.append(popper)
pages temp.pop()
    return
int(pages)
plugin.route('/')
def index():
categories parse_categories()
mixtapepage.update({'page'0})
items = [{
'label'li.find('a').contents[0].strip(),
'path'plugin.url_for('show_category'url='http://www.mixtapepage.com/' li.find('a')['href'].strip(), pnum '0'),
        } for
li in categories]
    return
items
@plugin.route('/category/<url>/<pnum>/')
def show_category(url,pnum):
page urllib2.urlopen(url)
thumbnails part_thumbnails(soup)
category_titles parse_category_titles(soup)
category_links parse_category_links(soup)
pages numberof_pages(soup)
#if pages != 0:
    #    mixtapepage['page'] += 1
if pages 0:
pnum int(pnum) + 1
        pnum
str(pnum)
items = [{
'label'title.find('h2').contents[0].strip(),
'label2'title.find('h2').contents[0].strip(),
'icon''http://www.mixtapepage.com/' thumbnail
'thumbnail' 'http://www.mixtapepage.com/' thumbnail,
'path''http://www.mixtapepage.com/' a
'is_playable'True,
        } for
titleathumbnail in zip(category_titlescategory_links,thumbnails)]
    if
mixtapepage['page'] <= pages:
items.append({
'label''Next Page',
'label2':'Next Page',
'path'plugin.url_for('show_category'urlurl.replace("http://www.mixtapepage.com/index.php?","http://www.mixtapepage.com/index.php?page=" pnum +"&"), pnum pnum),
    return
plugin.finish(items)
if
__name__ == '__main__':
plugin.run()
file: addon.xml
PHP Code:
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<addon id="plugin.music.mixtapepage" name="MixTapePage" version="0.1" provider-name="tz">
  <requires>
    <import addon="xbmc.python" version="2.0"/>
    <import addon="script.module.xbmcswift2" version="1.1.1"/>
     <import addon="script.module.beautifulsoup" version="3.0.8"/>
  </requires>
  <extension point="xbmc.python.pluginsource" library="addon.py">
    <provides>audio</provides>
  </extension>
  <extension point="xbmc.addon.metadata">
    <platform>all</platform>
    <language></language>
    <summary>Listen to Mixtapes or Download Mixtapes from a Mixtape Page. The newest Mixtapes streamed on your mobile phone for free.</summary>
    <description>Listen to Mixtapes or Download Mixtapes from a Mixtape Page. The newest Mixtapes streamed on your mobile phone for free.
    A first plugin by TommyZ !!</description>
  </extension>
</addon>
got it
So what was wrong? How did you fix it?
It was Mac OSX putting .DS files they all had to be removed
