I'm running XBMC Frodo on Ubuntu 12.10. I added the bluecop repo, but when I try to add any of the addons, they are marked as "Broken, dependencies not met.";
Any ideas?
Hi. I struggled with this too. What did it for me was deleting the Addons15.db under %AppData%/XBMC/userdata/Database (assuming you are under Windows) and restarting XBMC.[/align]
From the context menu, select "Force Refresh".
(2013-02-19, 15:21)neilperrya Wrote: [ -> ]Hi. I struggled with this too. What did it for me was deleting the Addons15.db under %AppData%/XBMC/userdata/Database (assuming you are under Windows) and restarting XBMC.[/align]
Thanks, I had tried forcing the refresh several times, but this did work for me!
