Full Version: Black Screen - Video Scaling Method problem
Hi All
Running Frodo on OSX and since the full GA release (did not experience this on any of the betas or
RCs), certain videos do not render an image.
On fiddling, I can see that if I goto the Video Scaling Method and change options from Auto, I get a flicker of the
video in between changing methods and then the actual video if I change to either Bilinear or Nearest
Neighbour. Both of which are a bit of a compromise.
I've not read of anyone else with this problem, any ideas?
Many THanks
11:50:20 T:4474802176 NOTICE: Thread CDVDPlayer start, auto delete: false
11:50:20 T:4474802176 NOTICE: Creating InputStream
11:50:21 T:4474802176 NOTICE: Creating Demuxer
11:50:21 T:4474802176 NOTICE: Opening video stream: 0 source: 256
11:50:21 T:4474802176 NOTICE: Creating video codec with codec id: 13
11:50:21 T:4474802176 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-4 part 2
11:50:21 T:4484169728 NOTICE: Thread CVideoReferenceClock start, auto delete: false
11:50:21 T:4474802176 NOTICE: Creating video thread
11:50:21 T:4541829120 NOTICE: Thread CDVDPlayerVideo start, auto delete: false
11:50:21 T:4541829120 NOTICE: running thread: video_thread
11:50:21 T:4474802176 NOTICE: Opening audio stream: 1 source: 256
11:50:21 T:4474802176 NOTICE: Finding audio codec for: 86017
11:50:21 T:4474802176 NOTICE: Creating audio thread
11:50:21 T:4542365696 NOTICE: Thread CDVDPlayerAudio start, auto delete: false
11:50:21 T:4542365696 NOTICE: running thread: CDVDPlayerAudio:Tonguerocess()
11:50:21 T:4542365696 NOTICE: Creating audio stream (codec id: 86017, channels: 2, sample rate: 48000, no pass-through)
11:50:21 T:4541829120 NOTICE: fps: 23.976024, pwidth: 560, pheight: 400, dwidth: 560, dheight: 400
11:50:21 T:4541829120 WARNING: CRenderManager::Configure - timeout waiting for previous frame
11:50:21 T:4541829120 NOTICE: Display resolution DESKTOP : 1280x720 @ 60.00 - Full Screen (16)
11:50:21 T:140735083510976 NOTICE: Using GL_TEXTURE_2D
11:50:21 T:140735083510976 NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
11:50:21 T:140735083510976 NOTICE: GL: NPOT texture support detected
11:50:21 T:140735083510976 NOTICE: GL: Using GL_ARB_pixel_buffer_object
humm - how did you select what you put in that useless log snippet? Post a full log top pastebin.com and put the link in here.
