2013-02-17, 15:40
Hi , i wondered if anyone could point me in the right direction with this issue ,
XBMC will work perfectly the first time round , YouTube file directory as an example will load up instantly and i'm able to select what i want to watch.
But after streaming one file , ill then go back to the various menus to try and play another stream on any other movie Addon and ill just keep getting the "Working" notification ( This is with any addon )
It wont even turn off through the shutdown menu! Its like it stops communicating with back end.
Anyone else had this problem? Is there a default procedure to carry out to fault find?
Regards,
Tom.
Regards,
Tom.
