Full Version: [SOLVED] Change All thumbnails&art to Highest Resolution?
Hi, I'm currently running XBMC 12.0 Frodo and wish to change the resolution of all artwork, fanart,coverart etc. I know you can do it throught the advancedsettings.xml but I dont know the exact way of writing the script. Could someone give me an example?
Any help is much appreciated.
Look at http://wiki.xbmc.org/index.php?title=Adv...ttings.xml
Specifically, fanartres for fanart and imageres for all other art. Where they refer to thumbres, I think you should read imageres.
The definitions are unclear, but it appears they mean the values are the heights in pixels. The defaults are already high, 1080 pixels high for fanart and 720 for other art, so I'm not sure there is much to be gained by increasing them. But maybe you want to decrease the resolution.
(2013-02-17, 23:51)Glorious1 Wrote: [ -> ]Look at http://wiki.xbmc.org/index.php?title=Adv...ttings.xml
Hi Glorious, Many thanks for you're reply its much appreciated. You're advice worked a treat Big Grin I have the Coverart set at 1080 and its caching them at that aswell without any drop in performance YAY!
