2013-02-18, 04:56
Hi all
I've had a look around for how to solve this problem, but it's a but hard with the volumes of info available, hopefully it is just one of those things with a really simple explanation and fix. I'm quite OK with editing XML files, if that's what's needed.
I've just set up XBMC Frodo as a new install. I'd used Ember Media Manager to download some metadata, and then used XBMC to update its own libraries.
I'm using the default Confluence skin, and the Media Info 3 layout to view movies, and would like to have a plain wallpaper behind the list and metadata, instead of repeating the fanart as it does now. I posted a capture of this at http://www.flickr.com/photos/emueyes/848...hotostream The same sort of thing happens in other views, too.
To my mind it makes the screen look cluttered, just the one image above the details would be great. I don't want to get rid of all the fanart, just the display as wallpaper.
TIA
TIA
