2013-02-18, 22:11
So I have tried a lot to fix this. Basically I have a laptop that I need to close the lid on while it's connected to the telly. However, everything I have tried has not worked. Here is what I've done:
I set gconftool to change lid settings:
That didn't work, so I installed gnome-settings-daemon and changed the lid settiings:
That still didn't work, so I tried changing the lock screen settings:
That still doesn't work so I got despirate and tried to just get rid of lock screen period:
Here is my current readout for power settings:
I'm seriously lost here. I have no idea what else to try.
BTW, I'm using the 12.00.Intel-NVIDIA XBMCBuntu image.
gconftool-2 --type string --set /apps/gnome-power-manager/buttons/lid_battery "nothing"
gconftool-2 --type string --set /apps/gnome-power-manager/buttons/lid_ac "nothing"
gsettings set org.gnome.settings-daemon.plugins.power lid-close-ac-action nothing
gsettings set org.gnome.settings-daemon.plugins.power lid-close-ac-battery nothing
gsettings set org.gnome.desktop.screensaver lock-enabled false
gsettings set org.gnome.desktop.lockdown disable-lock-screen true
sed -i.bak s/'LOCK_SCREEN=true'/'LOCK_SCREEN=false'/ /etc/default/acpi-support
org.gnome.settings-daemon.plugins.power active true
org.gnome.settings-daemon.plugins.power button-hibernate 'hibernate'
org.gnome.settings-daemon.plugins.power button-power 'suspend'
org.gnome.settings-daemon.plugins.power button-sleep 'hibernate'
org.gnome.settings-daemon.plugins.power button-suspend 'suspend'
org.gnome.settings-daemon.plugins.power critical-battery-action 'hibernate'
org.gnome.settings-daemon.plugins.power idle-brightness 30
org.gnome.settings-daemon.plugins.power idle-dim-ac false
org.gnome.settings-daemon.plugins.power idle-dim-battery true
org.gnome.settings-daemon.plugins.power idle-dim-time 90
org.gnome.settings-daemon.plugins.power lid-close-ac-action 'nothing'
org.gnome.settings-daemon.plugins.power lid-close-battery-action 'nothing'
org.gnome.settings-daemon.plugins.power notify-perhaps-recall true
org.gnome.settings-daemon.plugins.power percentage-action 2
org.gnome.settings-daemon.plugins.power percentage-critical 3
org.gnome.settings-daemon.plugins.power percentage-low 10
org.gnome.settings-daemon.plugins.power priority 1
org.gnome.settings-daemon.plugins.power sleep-display-ac 600
org.gnome.settings-daemon.plugins.power sleep-display-battery 600
org.gnome.settings-daemon.plugins.power sleep-inactive-ac-timeout 0
org.gnome.settings-daemon.plugins.power sleep-inactive-ac-type 'suspend'
org.gnome.settings-daemon.plugins.power sleep-inactive-battery-timeout 0
org.gnome.settings-daemon.plugins.power sleep-inactive-battery-type 'suspend'
org.gnome.settings-daemon.plugins.power time-action 120
org.gnome.settings-daemon.plugins.power time-critical 300
org.gnome.settings-daemon.plugins.power time-low 1200
org.gnome.settings-daemon.plugins.power use-time-for-policy true
