2013-02-19, 10:32
Hi there !
First, i'm french and i hope my english is quite good to make me understand. I start building a htpc and i'm facing a problem that i'm not able to solve alone, that's why i came here
I installed Openelec 2.99.2 from an usb stick with no problems during installation. For configuration, i use a classic keyboard but Yatse is already installed on my phone. My htpc is connected to my tv by hdmi and i use the default skin. Once started, when i navigate in the menu, the display freeze. It's not totaly a freeze because when i use the keyboard, the action arrive some seconds later, but very very smoothly, and samba and ssh works.
Impossible to generate this problem, because it came totaly randomly. Generally, this happens between 10 and 20 secondes after xbmc is launched.
My config :
My logs : Link on dropbox to my logs
When i use the IGP of my motherboard, connected by VGA to the TV, all works good. The bios of the motherboard is up to date. This problem is also present with XBMCbuntu.
If you need more information, feel free to ask me !
My config :
Quote:Processeur : INTEL Pentium Dual Core G645
CG : Asus GeForce GT 610 - 1024 Mo
CM : ASUS P8H61-I LX R2.0
Alim : Corsair CX Bronze - 430W
Boitier : Fractal Design Node 605
DD : Western Caviar Blue 1TB 64MB 3.5IN SATA 6 GB/S 7200RPM
