Full Version: Specifying video library export path
Sup folks,
I'd like to export my video library as separate files but XBMC attempts to write them in the same read-only SMB share as the media itself.
Does anyone know if it's possible to specify the output path, perhaps using advancedsettings.xml?
-- XBMC 12.0 Windows
not possible for separate files. the files can only be used if they sit along the media..
(2013-02-20, 18:07)spiff Wrote: [ -> ]not possible for separate files. the files can only be used if they sit along the media..
I see. Thanks for the info.
I guess I'm going to have to try the single file export method and hope that it'll work just the same when re-importing for the switch to MySQL.
