Full Version: XBMC Crash
Hi I,m new here new to XBMC and Linux as a whole. I am trying to build a media pc withXBMC.I have an ASUS motherboard and AMD sepmron cpu with intergrated Radeon HD 4250 graphics. My computer will not load XBMC I can only go log into XBMCbuntu. if I try to swap to XBMC it crashes back to the login. I have no idea why. Can anyone help me?
here is the crash log
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Wed Feb 20 18:45:10 GMT 2013
XBMC Options:
Arch: i686
Kernel: Linux 3.5.0-24-generic #37-Ubuntu SMP Thu Feb 7 05:32:22 UTC 2013
Release:
Distributor ID: Ubuntu
Description: Ubuntu 12.10 - XBMCbuntu
Release: 12.10
Codename: quantal
############## END SYSTEM INFO ##############
############### STACK TRACE #################
gdb not installed, can't get stack trace.
############# END STACK TRACE ###############
################# LOG FILE ##################
18:45:09 T:3038201600 NOTICE: -----------------------------------------------------------------------
18:45:09 T:3038201600 NOTICE: Starting XBMC (12.0 Git:fb595f2), Platform: Linux (Ubuntu 12.10 - XBMCbuntu, 3.5.0-24-generic i686). Built on Jan 28 2013
18:45:09 T:3038201600 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
18:45:09 T:3038201600 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
18:45:09 T:3038201600 NOTICE: special://masterprofile/ is mapped to: /home/steve/.xbmc/userdata
18:45:09 T:3038201600 NOTICE: special://home/ is mapped to: /home/steve/.xbmc
18:45:09 T:3038201600 NOTICE: special://temp/ is mapped to: /home/steve/.xbmc/temp
18:45:09 T:3038201600 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
18:45:09 T:3038201600 NOTICE: Local hostname: steve-System-Product-Name
18:45:09 T:3038201600 NOTICE: Log File is located: /home/steve/.xbmc/temp/xbmc.log
18:45:09 T:3038201600 ERROR: CAESinkOSS::EnumerateDevicesEx - Failed to open mixer: /dev/mixer
18:45:09 T:3038201600 NOTICE: Enumerated ALSA devices:
18:45:09 T:3038201600 NOTICE: Device 1
18:45:09 T:3038201600 NOTICE: m_deviceName : @
18:45:09 T:3038201600 NOTICE: m_displayName : Default (HDA ATI SB ALC892 Analog)
18:45:09 T:3038201600 NOTICE: m_displayNameExtra:
18:45:09 T:3038201600 NOTICE: m_deviceType : AE_DEVTYPE_PCM
18:45:09 T:3038201600 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE,SL,SR
18:45:09 T:3038201600 NOTICE: m_sampleRates : 44100,48000,96000,192000
18:45:09 T:3038201600 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
18:45:09 T:3038201600 NOTICE: Device 2
18:45:09 T:3038201600 NOTICE: m_deviceName : @:CARD=SB,DEV=0
18:45:09 T:3038201600 NOTICE: m_displayName : HDA ATI SB
18:45:09 T:3038201600 NOTICE: m_displayNameExtra: ALC892 Analog
18:45:09 T:3038201600 NOTICE: Device 3
18:45:09 T:3038201600 NOTICE: m_deviceName : iec958:CARD=SB,DEV=0
18:45:09 T:3038201600 NOTICE: m_displayNameExtra: ALC892 Digital S/PDIF
18:45:09 T:3038201600 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
18:45:09 T:3038201600 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,192000
18:45:09 T:3038201600 NOTICE: Device 4
18:45:09 T:3038201600 NOTICE: m_deviceName : hdmi:CARD=HDMI,DEV=0
18:45:09 T:3038201600 NOTICE: m_displayNameExtra: HDMI
18:45:09 T:3038201600 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
18:45:09 T:3038201600 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE
18:45:09 T:3038201600 NOTICE: load settings...
18:45:09 T:3038201600 ERROR: Unable to load libcrystalhd.so.3, reason: libcrystalhd.so.3: cannot open shared object file: No such file or directory
18:45:09 T:3038201600 NOTICE: special://profile/ is mapped to: special://masterprofile/
18:45:09 T:3038201600 NOTICE: loading special://masterprofile/guisettings.xml
18:45:09 T:3038201600 ERROR: special://masterprofile/guisettings.xml Doesn't contain <resolutions>
18:45:09 T:3038201600 NOTICE: Getting hardware information now...
18:45:09 T:3038201600 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
18:45:09 T:3038201600 NOTICE: Loaded playercorefactory configuration
18:45:09 T:3038201600 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
18:45:09 T:3038201600 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
18:45:09 T:3038201600 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
18:45:09 T:3038201600 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
18:45:09 T:3038201600 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<useddsfanart>true</useddsfanart>
<cputempcommand>cputemp</cputempcommand>
<gputempcommand>gputemp</gputempcommand>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
<network>
<disableipv6>true</disableipv6>
</network>
</advancedsettings>
18:45:09 T:3038201600 NOTICE: Default DVD Player: dvdplayer
18:45:09 T:3038201600 NOTICE: Default Video Player: dvdplayer
18:45:09 T:3038201600 NOTICE: Default Audio Player: paplayer
18:45:09 T:3038201600 NOTICE: Disabled debug logging due to GUI setting. Level 0.
18:45:09 T:3038201600 NOTICE: Log level changed to 0
18:45:09 T:3038201600 NOTICE: Loading media sources from special://masterprofile/sources.xml
18:45:09 T:2970807104 NOTICE: Thread CSoftAE start, auto delete: false
18:45:09 T:3038201600 NOTICE: Running database version Addons15
18:45:09 T:3035446080 NOTICE: Thread XBMC Peripherals start, auto delete: false
18:45:09 T:3038201600 NOTICE: Setup SDL
18:45:09 T:3038201600 NOTICE: Checking resolution 16
18:45:09 T:3038201600 NOTICE: Using visual 0x114
18:45:09 T:3038201600 NOTICE: GL_VENDOR = VMware, Inc.
18:45:09 T:3038201600 NOTICE: GL_RENDERER = Gallium 0.4 on llvmpipe (LLVM 0x301)
18:45:09 T:3038201600 NOTICE: GL_VERSION = 2.1 Mesa 9.0
18:45:09 T:3038201600 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.20
18:45:09 T:3038201600 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_multitexture GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_compression_s3tc GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_fog_distance GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_MESA_ycbcr_texture GL_NV_primitive_restart GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_ATI_texture_compression_3dc GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_ATI_texture_mirror_once GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_compression_latc GL_EXT_texture_sRGB_decode GL_OES_EGL_image GL_ARB_copy_buffer GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_separate_shader_objects GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_AMD_draw_buffers_blend GL_ARB_ES2_compatibility GL_ARB_debug_output GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sampler_objects GL_ARB_shader_texture_lod GL_ARB_vertex_type_2_10_10_10_rev GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_ARB_robustness GL_ARB_texture_storage GL_ARB_invalidate_subdata
18:45:09 T:3038201600 ERROR: GLX: Same window as before, refreshing context
18:45:09 T:3038201600 NOTICE: Running database version ViewModes4
18:45:09 T:3038201600 NOTICE: Running database version Textures13
18:45:09 T:3038201600 NOTICE: Running database version MyMusic32
18:45:09 T:3038201600 NOTICE: Running database version MyVideos75
18:45:09 T:3038201600 NOTICE: Running database version TV22
18:45:09 T:3038201600 NOTICE: Running database version Epg7
18:45:09 T:3038201600 NOTICE: start dvd mediatype detection
18:45:09 T:3038201600 NOTICE: initializing playlistplayer
18:45:09 T:3038201600 NOTICE: DONE initializing playlistplayer
18:45:09 T:2962414400 NOTICE: Thread CDetectDVDMedia start, auto delete: false
18:45:10 T:3038201600 NOTICE: initialize done
18:45:10 T:3038201600 NOTICE: Running the application...
18:45:10 T:2922523456 NOTICE: Thread Jobworker start, auto delete: true
18:45:10 T:3038201600 NOTICE: ES: Starting event server
18:45:10 T:2905738048 NOTICE: Thread CTCPServer start, auto delete: false
18:45:10 T:3038201600 NOTICE: starting zeroconf publishing
18:45:10 T:2888952640 NOTICE: Thread Jobworker start, auto delete: true
18:45:10 T:2914130752 NOTICE: Thread CEventServer start, auto delete: false
18:45:10 T:2914130752 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
18:45:10 T:2914130752 NOTICE: UDP: Listening on port 9777
18:45:10 T:2872261440 NOTICE: Thread Jobworker start, auto delete: true
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
Welcome
Please read wiki and or forums before posting on about known issues with known solutions
http://forum.xbmc.org/showthread.php?tid...pid1321833
And please remove that large log from your first post, aroud these parts its pastebins only for logs, thx
uNi
