Full Version: Can't delete EPG/PVR database
I lost network one evening and it crashed XBMC/tvheadend and now PVR doesn't work anymore.
XBMC reports no PVR client is initialised.
I've uninstalled tvheadend and reinstalled via the Add-ons setting to no avail.
When I try and Delete the PVR or the EPG database, XBMC hangs.
How do I force delete/drop the database?
stop xbmc, delete ~/.xbmc/userdata/Database/Epg*.db and ~/.xbmc/userdata/Database/TV*.db
apologies - forgot to mention I use Openelec.
Is there a way to do that in Openelec as I don't think I can stop XBMC?
you needed to touch some file before killing xbmc, but i completely forgot which one cause i don't use this very often. some OE expert better answer this ;-)
touch /var/lock/xbmc.disabled, I believe
thanks!
