Full Version: Files are played too fast [not only AirPlay]
Since I have switched to Win 7 everything works great, except:
AirPlay.
Well, I can play Video and Auio without any problems - but it plays to fast!
[EDIT:] Many files, in SD-quality are played to fast.
It's on like - maybe 1.2x - 1.5x speed. You can hear the sound is also pitched.
Of course the puffer is running low then and I have a short pause every 5s or so. [<- Using AirPlay]
Video-Streaming worked well with Eden and WinXP.
Anybody an idea?
My System:
  • Win 7 32Bit
  • XonarDX (shouldn't cause the problem)
  • XBMC Frodo
  • iPhone 4 iOS 6.1 (shouldn't cause the problem)
  • iPad 2 iOS 6.1 (shouldn't cause the problem)
Now guess which info is missing?
oops.
Blush
16:27:40 T:2156  NOTICE: -----------------------------------------------------------------------
16:27:40 T:2156  NOTICE: Starting XBMC (12.0 Git:20130127-fb595f2), Platform: Windows 7 32-bit, build 7600. Built on Jan 28 2013 (compiler 1600)
16:27:40 T:2156  NOTICE: Intel(R) Core(TM)2 CPU          6300  @ 1.86GHz
16:27:40 T:2156  NOTICE: Desktop Resolution: 1920x1080 32Bit at 30Hz
16:27:40 T:2156  NOTICE: Running with restricted rights
16:27:40 T:2156  NOTICE: Aero is disabled
16:27:40 T:2156  NOTICE: special://xbmc/ is mapped to: C:\Program Files\XBMC
16:27:40 T:2156  NOTICE: special://xbmcbin/ is mapped to: C:\Program Files\XBMC
16:27:40 T:2156  NOTICE: special://masterprofile/ is mapped to: C:\Users\dc7700\AppData\Roaming\XBMC\userdata
16:27:40 T:2156  NOTICE: special://home/ is mapped to: C:\Users\dc7700\AppData\Roaming\XBMC\
16:27:40 T:2156  NOTICE: special://temp/ is mapped to: C:\Users\dc7700\AppData\Roaming\XBMC\cache
16:27:40 T:2156  NOTICE: The executable running is: C:\Program Files\XBMC\XBMC.exe
16:27:40 T:2156  NOTICE: Local hostname: dc7700-PC
16:27:40 T:2156  NOTICE: Log File is located: C:\Users\dc7700\AppData\Roaming\XBMC\xbmc.log
16:27:40 T:2156  NOTICE: Enumerated DirectSound devices:
16:27:40 T:2156  NOTICE:     Device 1
16:27:40 T:2156  NOTICE:         m_deviceName      : {9DC76940-31BD-4C89-8EC7-75C139F5A37D}
16:27:40 T:2156  NOTICE:         m_displayName     : SPDIF - S/PDIF Pass-through Device (ASUS Xonar DX Audio Device)
16:27:40 T:2156  NOTICE:         m_displayNameExtra: DirectSound: S/PDIF Pass-through Device (ASUS Xonar DX Audio Device)
16:27:40 T:2156  NOTICE:         m_deviceType      : AE_DEVTYPE_IEC958
16:27:40 T:2156  NOTICE:         m_channels        : FL,FR
16:27:40 T:2156  NOTICE:         m_sampleRates     : 44100
16:27:40 T:2156  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_AC3
16:27:40 T:2156  NOTICE:     Device 2
16:27:40 T:2156  NOTICE:         m_deviceName      : {B8308F9A-7E2E-4A4E-9CB6-AB6596070C32}
16:27:40 T:2156  NOTICE:         m_displayName     : Speakers - Lautsprecher (ASUS Xonar DX Audio Device)
16:27:40 T:2156  NOTICE:         m_displayNameExtra: DirectSound: Lautsprecher (ASUS Xonar DX Audio Device)
16:27:40 T:2156  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
16:27:40 T:2156  NOTICE:         m_sampleRates     : 96000
16:27:40 T:2156  NOTICE:     Device 3
16:27:40 T:2156  NOTICE:         m_deviceName      : {D4E7BBBF-9D95-474F-A55F-E8F788567D9E}
16:27:40 T:2156  NOTICE:         m_displayName     : HDMI - Digitalaudio (HDMI) (2- High Definition Audio-Gerät)
16:27:40 T:2156  NOTICE:         m_displayNameExtra: DirectSound: Digitalaudio (HDMI) (2- High Definition Audio-Gerät)
16:27:40 T:2156  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
16:27:40 T:2156  NOTICE: Enumerated WASAPI devices:
16:27:40 T:2156  NOTICE:         m_displayNameExtra: WASAPI: S/PDIF Pass-through Device (ASUS Xonar DX Audio Device)
16:27:40 T:2156  NOTICE:         m_sampleRates     : 192000,96000,48000,44100
16:27:40 T:2156  NOTICE:         m_dataFormats     : AE_FMT_DTS,AE_FMT_AC3,AE_FMT_S24NE3,AE_FMT_S24LE3,AE_FMT_S24BE3,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
16:27:40 T:2156  NOTICE:         m_displayNameExtra: WASAPI: Lautsprecher (ASUS Xonar DX Audio Device)
16:27:40 T:2156  NOTICE:         m_channels        : FL,FR,FC,LFE,SL,SR,BL,BR
16:27:40 T:2156  NOTICE:         m_dataFormats     : AE_FMT_S24NE3,AE_FMT_S24LE3,AE_FMT_S24BE3,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
16:27:40 T:2156  NOTICE:         m_displayNameExtra: WASAPI: Digitalaudio (HDMI) (2- High Definition Audio-Gerät)
16:27:40 T:2156  NOTICE:         m_sampleRates     : 48000,44100,32000
16:27:40 T:2156  NOTICE:         m_dataFormats     : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
16:27:40 T:2156  NOTICE: load settings...
16:27:40 T:2156  NOTICE: special://profile/ is mapped to: special://masterprofile/
16:27:40 T:2156  NOTICE: loading special://masterprofile/guisettings.xml
16:27:40 T:2156  NOTICE: Getting hardware information now...
16:27:40 T:2156  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
16:27:40 T:2156  NOTICE: Loaded playercorefactory configuration
16:27:40 T:2156  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
16:27:40 T:2156  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
16:27:40 T:2156  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
16:27:40 T:2156  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
16:27:40 T:2156  NOTICE: Default DVD Player: dvdplayer
16:27:40 T:2156  NOTICE: Default Video Player: dvdplayer
16:27:40 T:2156  NOTICE: Default Audio Player: paplayer
16:27:40 T:2156  NOTICE: Enabled debug logging due to GUI setting (2)
16:27:40 T:2156  NOTICE: Log level changed to 2
16:27:40 T:2156  NOTICE: Loading media sources from special://masterprofile/sources.xml
16:27:40 T:2156    INFO: creating subdirectories
16:27:40 T:2156    INFO: userdata folder: special://masterprofile/
16:27:40 T:2156    INFO: recording folder:
16:27:40 T:2156    INFO: screenshots folder:
16:27:40 T:2156    INFO: thumbnails folder: special://masterprofile/Thumbnails
16:27:40 T:2156    INFO: load language info file: special://xbmc/language/German/langinfo.xml
16:27:40 T:2156   DEBUG: trying to set locale to deu_bel
16:27:40 T:2156    INFO: global locale set to German_Belgium.1252
16:27:40 T:2156    INFO: load German language file, from path: special://xbmc/language/
16:27:40 T:2156   DEBUG: POParser: PO file has Win Style Line Endings. Converted in memory to Linux LF for file: C:\Program Files\XBMC\language\German\strings.po
16:27:40 T:2156   DEBUG: POParser: loaded 2686 strings from file C:\Program Files\XBMC\language\German\strings.po
16:27:40 T:2156   DEBUG: POParser: PO file has Win Style Line Endings. Converted in memory to Linux LF for file: C:\Program Files\XBMC\language\English\strings.po
16:27:40 T:2156   DEBUG: POParser: loaded 0 strings from file C:\Program Files\XBMC\language\English\strings.po
16:27:40 T:2156    INFO: CSoftAE::InternalOpenSink - sink incompatible, re-starting
16:27:41 T:2156   DEBUG: CAESinkDirectSound::Initialize: Using Window handle: 65552
16:27:41 T:2156   DEBUG: CAESinkDirectSound::Initialize: secondary buffer created
16:27:41 T:2156   DEBUG: CAESinkDirectSound::Initialize: Initializing DirectSound with the following parameters:
16:27:41 T:2156   DEBUG:   Audio Device    : S/PDIF Pass-through Device (ASUS Xonar DX Audio Device)
16:27:41 T:2156   DEBUG:   Sample Rate     : 44100
16:27:41 T:2156   DEBUG:   Sample Format   : AE_FMT_FLOAT
16:27:41 T:2156   DEBUG:   Bits Per Sample : 32
16:27:41 T:2156   DEBUG:   Valid Bits/Samp : 32
16:27:41 T:2156   DEBUG:   Channel Count   : 2
16:27:41 T:2156   DEBUG:   Block Align     : 8
16:27:41 T:2156   DEBUG:   Avg. Bytes Sec  : 352800
16:27:41 T:2156   DEBUG:   Samples/Block   : 32
16:27:41 T:2156   DEBUG:   Format cBSize   : 22
16:27:41 T:2156   DEBUG:   Channel Layout  : FL,FR
16:27:41 T:2156   DEBUG:   Channel Mask    : 3
16:27:41 T:2156   DEBUG:   Frames          : 441
16:27:41 T:2156   DEBUG:   Frame Samples   : 882
16:27:41 T:2156   DEBUG:   Frame Size      : 8
16:27:41 T:2156   DEBUG: CSoftAE::InternalOpenSink - DirectSound Initialized:
16:27:41 T:2156   DEBUG:   Output Device : SPDIF - S/PDIF Pass-through Device (ASUS Xonar DX Audio Device)
16:27:41 T:2156   DEBUG:   Channel Layout: FL,FR
16:27:41 T:2156   DEBUG: CSoftAE::InternalOpenSink - Using speaker layout: 2.0
16:27:41 T:2156   DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 3528
16:27:41 T:3164  NOTICE: Thread CSoftAE start, auto delete: false
16:27:41 T:3164    INFO: CSoftAE::Run - Thread Started
16:27:41 T:2156  NOTICE: Running database version Addons15
16:27:41 T:2156   DEBUG: SECTION:LoadDLL(special://xbmcbin/system/cpluff.dll)
16:27:41 T:3164   DEBUG: CAESinkDirectSound::CheckPlayStatus: Resuming Playback
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in xbmc.json has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.fanart.tv has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in webinterface.default has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in repository.xbmc.org has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.black has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in screensaver.rsxs.euphoria has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in pvr.vdr.vnsi has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in pvr.argustv has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in repository.pvr-osx32.xbmc.org has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in pvr.mediaportal.tvserver has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in visualization.projectm has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in weather.wunderground has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in script.module.simplejson has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.dim has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.themoviedb.org has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in xbmc.metadata has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in repository.pvr-ios.xbmc.org has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in skin.confluence has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in visualization.glspectrum has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in xbmc.gui has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in visualization.milkdrop has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in script.module.pil has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.amazon.de has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in visualization.dxspectrum has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in pvr.vuplus has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.musicvideos.theaudiodb.com has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in xbmc.core has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in screensaver.rsxs.solarwinds has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in pvr.demo has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in xbmc.pvr has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in pvr.njoy has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in pvr.nextpvr has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in repository.pvr-android.xbmc.org has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.album.universal has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.htbackdrops.com has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in repository.pvr-win32.xbmc.org has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in pvr.dvbviewer has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in repository.pvr-osx64.xbmc.org has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in pvr.mythtv.cmyth has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.tvdb.com has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.musicbrainz.org has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.allmusic.com has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.last.fm has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.themoviedb.org has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.theaudiodb.com has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.artists.universal has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in xbmc.python has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.imdb.com has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in xbmc.addon has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in visualization.waveform has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in screensaver.rsxs.plasma has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in pvr.hts has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in script.module.pysqlite has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.hdtrailers.net has been installed.'
16:27:41 T:2156   DEBUG: ADDON: cpluff: 'Not all directories were successfully scanned.'
16:27:41 T:2156   DEBUG: PERIPHERALS::CPeripherals::LoadMappings - loaded node "Motorola Nyxboard Hybrid"
16:27:41 T:2156   DEBUG: PERIPHERALS::CPeripherals::LoadMappings - loaded node "Raspberry Pi CEC Adapter"
16:27:41 T:2156   DEBUG: PERIPHERALS::CPeripherals::LoadMappings - loaded node "Pulse-Eight CEC Adapter"
16:27:41 T:2156   DEBUG: PERIPHERALS::CPeripherals::LoadMappings - loaded node "iMON HID device"
16:27:41 T:2892  NOTICE: Thread XBMC Peripherals start, auto delete: false
16:27:41 T:1104  NOTICE: Thread CRemoteControl start, auto delete: false
16:27:41 T:2156   DEBUG: CWIN32Util::GetDriveStatus: Requesting status for drive \\.\E:.
16:27:41 T:2156   DEBUG: CWIN32Util::GetDriveStatus: Requesting media status for drive \\.\E:.
16:27:41 T:2156  NOTICE: Found screen: PnP-Monitor (Standard) on ATI Radeon HD 5400 Series, adapter 0.
16:27:41 T:2156  NOTICE: Primary mode: 1920x1080 @ 30.00i - Full Screen
16:27:41 T:1044  NOTICE: Thread Jobworker start, auto delete: true
16:27:41 T:1044   DEBUG: CDetectDisc::DoWork: Optical media found in drive E:
16:27:41 T:2156  NOTICE: Additional mode: 640x480 @ 23.98 - Full Screen
16:27:41 T:2156  NOTICE: Additional mode: 640x480 @ 24.00 - Full Screen
16:27:41 T:1104   DEBUG: CRemoteControl::Connect - connecting to: ::1:24000 ...
16:27:41 T:2156  NOTICE: Additional mode: 640x480 @ 50.00 - Full Screen
16:27:41 T:2156  NOTICE: Previous line repeats 2 times.
16:27:41 T:2156  NOTICE: Additional mode: 640x480 @ 60.00 - Full Screen
[... Many more additional modes ...]
16:27:41 T:2156  NOTICE: Checking resolution 16
16:27:41 T:2156   DEBUG: CWinEventsWin32::WndProc: window resize event
16:27:41 T:2156   DEBUG: CWinEventsWin32::WndProc: window move event
16:27:41 T:2156   DEBUG: CWinSystemWin32::ResizeInternal - resizing due to size change (0,0,1920,1080 fullscreen)->(0,0,1920,1080 fullscreen)
16:27:41 T:2156   DEBUG: CWinEventsWin32::WndProcWindow is active
16:27:42 T:2156   DEBUG: CRenderSystemDX::InitRenderSystem - trying D3D9Ex...
16:27:42 T:2156   DEBUG: CRenderSystemDX::InitRenderSystem - using D3D9Ex
16:27:42 T:2156   DEBUG: CRenderSystemDX::CreateDevice on adapter 0
16:27:42 T:2156   DEBUG: CRenderSystemDX::CreateDevice - using hardware vertex processing
16:27:42 T:2156   DEBUG: CRenderSystemDX::CreateDevice - adapter 0: aticfx32.dll, ATI Radeon HD 5400 Series, VendorId 4098, DeviceId 26849
16:27:42 T:2156   DEBUG: CRenderSystemDX::CreateDevice - using D3DCAPS2_DYNAMICTEXTURES
16:27:42 T:2156   DEBUG: CRenderSystemDX::CreateDevice - texture caps: 0x0001EC45
16:27:42 T:2156   DEBUG: CRenderSystemDX::CreateDevice - RENDER_CAPS_DXT
16:27:42 T:2156   DEBUG: CRenderSystemDX::CreateDevice - RENDER_CAPS_NPOT
16:27:42 T:2156   DEBUG: CRenderSystemDX::CreateDevice - RENDER_CAPS_DXT_NPOT
16:27:42 T:2156   DEBUG: CWinSystemWin32::SetFullScreen (true fullscreen) on screen 0 with size 1920x1080, refresh 30.000000i
16:27:42 T:1104   DEBUG: CRemoteControl::Connect - connecting to: 127.0.0.1:24000 ...
16:27:42 T:2156   DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
16:27:42 T:2156    INFO: load default splash image: C:\Program Files\XBMC\media\Splash.png
16:27:42 T:2156   DEBUG: SECTION:LoadDLL(special://xbmcbin/system/ImageLib.dll)
16:27:42 T:2156    INFO: load keymapping
16:27:42 T:2156    INFO: Loading special://xbmc/system/keymaps/appcommand.xml
16:27:42 T:2156    INFO: Loading special://xbmc/system/keymaps/gamepad.xml
16:27:42 T:2156    INFO: Loading special://xbmc/system/keymaps/joystick.Alienware.Dual.Compatible.Controller.xml
16:27:42 T:2156    INFO: Loading special://xbmc/system/keymaps/joystick.AppleRemote.xml
16:27:42 T:2156    INFO: Loading special://xbmc/system/keymaps/joystick.Harmony.xml
16:27:42 T:2156    INFO: Loading special://xbmc/system/keymaps/joystick.Interact.AxisPad.xml
16:27:42 T:2156    INFO: Loading special://xbmc/system/keymaps/joystick.Logitech.RumblePad.2.xml
16:27:42 T:2156    INFO: Loading special://xbmc/system/keymaps/joystick.Microsoft.Xbox.360.Controller.xml
16:27:42 T:2156    INFO: Loading special://xbmc/system/keymaps/joystick.Microsoft.Xbox.Controller.S.xml
16:27:42 T:2156    INFO: Loading special://xbmc/system/keymaps/joystick.PS3.Remote.Keyboard.xml
16:27:42 T:2156    INFO: Loading special://xbmc/system/keymaps/joystick.Sony.PLAYSTATION(R)3.Controller.xml
16:27:42 T:2156    INFO: Loading special://xbmc/system/keymaps/joystick.WiiRemote.xml
16:27:42 T:2156    INFO: Loading special://xbmc/system/keymaps/keyboard.xml
16:27:42 T:2156    INFO: Loading special://xbmc/system/keymaps/mouse.xml
16:27:42 T:2156    INFO: Loading special://xbmc/system/keymaps/remote.xml
16:27:42 T:2156    INFO: Loading special://xbmc/system/IRSSmap.xml
16:27:42 T:2156    INFO: * Adding remote mapping for device 'Microsoft MCE'
16:27:42 T:2156    INFO: * Adding remote mapping for device 'Abstract'
16:27:42 T:2156   DEBUG: CButtonTranslator::Load - no userdata IRSSmap.xml found, skipping
16:27:42 T:2156    INFO: GUI format 1920x1080, Display 1920x1080 @ 30.00i - Full Screen
16:27:42 T:2156   DEBUG: guilib: Fill viewport on change for solving rendering passes
16:27:42 T:2156   DEBUG: SECTION:LoadDLL(special://xbmcbin/system/libcurl.dll)
16:27:42 T:2156  NOTICE: Running database version Addons15
16:27:42 T:2156   DEBUG: CDatabaseManager::Initialize, updating databases...
16:27:42 T:2156  NOTICE: Running database version ViewModes4
16:27:42 T:2156  NOTICE: Running database version Textures13
16:27:42 T:2156  NOTICE: Running database version MyMusic32
16:27:42 T:2156  NOTICE: Running database version MyVideos75
16:27:42 T:2156  NOTICE: Running database version TV22
16:27:42 T:2156  NOTICE: Running database version Epg7
16:27:42 T:2156   DEBUG: CDatabaseManager::Initialize, updating databases... DONE
16:27:42 T:2156  NOTICE: initializing playlistplayer
16:27:42 T:2156  NOTICE: DONE initializing playlistplayer
16:27:42 T:2156   DEBUG: DPMS: supported power-saving modes: OFF STANDBY
16:27:42 T:2156   DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
16:27:42 T:2156   DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnClear
16:27:42 T:2156    INFO: Unloading old skin ...
16:27:42 T:2156    INFO:   load skin from: C:\Program Files\XBMC\addons\skin.confluence (version: 2.1.3)
16:27:42 T:2156    INFO:   load fonts for skin...
16:27:42 T:2156    INFO: Loading fonts from C:\Program Files\XBMC\addons\skin.confluence\720p\Font.xml
16:27:42 T:2156   DEBUG: POParser: PO file has Win Style Line Endings. Converted in memory to Linux LF for file: C:\Program Files\XBMC\addons\skin.confluence\language\German\strings.po
16:27:42 T:2156   DEBUG: POParser: loaded 131 strings from file C:\Program Files\XBMC\addons\skin.confluence\language\German\strings.po
16:27:42 T:2156   DEBUG: POParser: PO file has Win Style Line Endings. Converted in memory to Linux LF for file: C:\Program Files\XBMC\addons\skin.confluence\language\English\strings.po
16:27:42 T:2156   DEBUG: POParser: loaded 0 strings from file C:\Program Files\XBMC\addons\skin.confluence\language\English\strings.po
16:27:42 T:2156    INFO: Loading skin includes from C:\Program Files\XBMC\addons\skin.confluence\720p\includes.xml
16:27:43 T:2156    INFO:   load new skin...
16:27:43 T:2156    INFO: Loading user windows, path C:\Program Files\XBMC\addons\skin.confluence\720p
16:27:43 T:2156   DEBUG: Load Skin XML: 4.45ms
16:27:43 T:2156    INFO:   initialize new skin...
16:27:43 T:2156   DEBUG: guilib: Fill viewport on change for solving rendering passes
16:27:43 T:2156    INFO: Loading skin file: Pointer.xml, load type: LOAD_ON_GUI_INIT
16:27:43 T:2156   DEBUG: CTextureBundleXBT::OpenBundle - Opened bundle C:\Program Files\XBMC\addons\skin.confluence\media\Textures.xbt
16:27:43 T:2156    INFO: Loading skin file: DialogVolumeBar.xml, load type: LOAD_ON_GUI_INIT
16:27:43 T:2156    INFO: Loading skin file: DialogKaiToast.xml, load type: LOAD_ON_GUI_INIT
16:27:43 T:2156    INFO: Loading skin file: DialogMuteBug.xml, load type: LOAD_ON_GUI_INIT
16:27:43 T:2156    INFO: Loading skin file: DialogSeekBar.xml, load type: LOAD_ON_GUI_INIT
16:27:43 T:2156    INFO: Loading skin file: DialogBusy.xml, load type: LOAD_ON_GUI_INIT
16:27:43 T:2156    INFO: Loading skin file: DialogExtendedProgressBar.xml, load type: LOAD_ON_GUI_INIT
16:27:43 T:2156    INFO: Loading C:\Program Files\XBMC\addons\skin.confluence\sounds\sounds.xml
16:27:43 T:2156    INFO: CAEWAVLoader::Initialize - Sound Loaded: C:\Program Files\XBMC\addons\skin.confluence\sounds\cursor.wav
16:27:43 T:2156    INFO: CAEWAVLoader::Initialize - Sound Loaded: C:\Program Files\XBMC\addons\skin.confluence\sounds\click.wav
16:27:43 T:2156    INFO: CAEWAVLoader::Initialize - Sound Loaded: C:\Program Files\XBMC\addons\skin.confluence\sounds\back.wav
16:27:43 T:2156   DEBUG: AERemap: Downmix normalization is disabled
16:27:43 T:2156    INFO: CAEWAVLoader::Initialize - Sound Loaded: C:\Program Files\XBMC\addons\skin.confluence\sounds\shutter.wav
16:27:43 T:2156    INFO: CAEWAVLoader::Initialize - Sound Loaded: C:\Program Files\XBMC\addons\skin.confluence\sounds\notify.wav
16:27:43 T:2156    INFO: CAEWAVLoader::Initialize - Sound Loaded: C:\Program Files\XBMC\addons\skin.confluence\sounds\out.wav
16:27:43 T:2156    INFO:   skin loaded...
16:27:43 T:2156    INFO: JSONRPC v6.0.0: Successfully initialized
16:27:43 T:2156   DEBUG: ADDON: Starting service addons.
16:27:43 T:2156   DEBUG: Activating window ID: 12999
16:27:43 T:2156   DEBUG: ------ Window Init (Startup.xml) ------
16:27:43 T:2156    INFO: Loading skin file: Startup.xml, load type: LOAD_EVERY_TIME
16:27:43 T:2156    INFO: removing tempfiles
16:27:43 T:2156  NOTICE: initialize done
16:27:43 T:2156   DEBUG: CJoystick::Initialize : No Joystick found
16:27:43 T:2156  NOTICE: Running the application...
16:27:43 T:2156   DEBUG: CApplication::ExecuteXBMCAction : Translating ReplaceWindow(Home)
16:27:43 T:2156   DEBUG: CApplication::ExecuteXBMCAction : To ReplaceWindow(Home)
16:27:43 T:2156   DEBUG: Activating window ID: 10000
16:27:43 T:2156   DEBUG: ------ Window Init () ------
16:27:43 T:2156   DEBUG: ------ Window Init (Pointer.xml) ------
16:27:43 T:2156   DEBUG: ------ Window Deinit (Startup.xml) ------
16:27:43 T:2156   DEBUG: ------ Window Init (Home.xml) ------
16:27:43 T:2156    INFO: Loading skin file: Home.xml, load type: KEEP_IN_MEMORY
16:27:43 T:1104   DEBUG: CRemoteControl::Connect - failed to connect
16:27:43 T:1104    INFO: CRemoteControl::Process - failed to connect to irss, will keep retrying every 5 seconds
16:27:43 T:2156   DEBUG: XBPython::Process - no profile autoexec.py (C:\Users\dc7700\AppData\Roaming\XBMC\userdata\autoexec.py) found, skipping
16:27:43 T:2156   DEBUG: CNetwork::NetworkMessage - Starting network services
16:27:43 T:2156  NOTICE: Webserver: Starting...
16:27:43 T:1044   DEBUG: CRecentlyAddedJob::UpdateMusic() - Running RecentlyAdded home screen update
16:27:43 T:1044   DEBUG: GetRecentlyAddedAlbumSongs() query: SELECT songview.* FROM (SELECT idAlbum FROM albumview ORDER BY idAlbum DESC LIMIT 10) AS recentalbums JOIN songview ON songview.idAlbum=recentalbums.idAlbum
16:27:43 T:1044   DEBUG: CMusicDatabase::GetRecentlyAddedAlbums query: select * from albumview where strAlbum != '' order by idAlbum desc limit 10
16:27:43 T:2156  NOTICE: WebServer: Started the webserver
16:27:43 T:2156  NOTICE: ES: Starting event server
16:27:43 T:2156    INFO: JSONRPC Server: Successfully initialized
16:27:43 T:2156  NOTICE: starting zeroconf publishing
16:27:43 T:2864  NOTICE: Thread CTCPServer start, auto delete: false
16:27:43 T:204  NOTICE: Thread CEventServer start, auto delete: false
16:27:43 T:204  NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
16:27:43 T:204  NOTICE: UDP: Listening on port 9777
16:27:43 T:1044   DEBUG: CRecentlyAddedJob::UpdateVideos() - Running RecentlyAdded home screen update
16:27:43 T:2156   DEBUG: ZeroconfWIN:Bonjour version is 333.10
16:27:43 T:2156    INFO: AIRPLAY Server: Successfully initialized
16:27:43 T:2852  NOTICE: Thread AirPlayServer start, auto delete: false
16:27:43 T:2156   DEBUG: SECTION:LoadDLL(special://xbmcbin/system/airplay/libshairplay-1.dll)
16:27:43 T:2156   DEBUG: CLastfmScrobbler: Clearing session.
16:27:43 T:2156   DEBUG: CLibrefmScrobbler: Clearing session.
16:27:43 T:1592  NOTICE: Thread Jobworker start, auto delete: true
16:27:43 T:1044   DEBUG: CVideoDatabase::RunQuery took 34 ms for 10 items query: select * from movieview  ORDER BY dateAdded desc, idMovie desc LIMIT 10
16:27:43 T:3120  NOTICE: Thread Jobworker start, auto delete: true
16:27:43 T:3120   DEBUG: ZeroconfWIN: identifier: servers.eventserver type: _xbmc-events._udp name:XBMC (dc7700-PC) port:9777
16:27:43 T:1592   DEBUG: ZeroconfWIN: identifier: servers.jsonrpc-http type: _xbmc-jsonrpc-h._tcp name:XBMC (dc7700-PC) port:80
16:27:43 T:3120   DEBUG: ZeroconfWIN: identifier: servers.airplay type: _airplay._tcp name:XBMC (dc7700-PC) port:36667
16:27:43 T:3120   DEBUG: ZeroconfWIN: key:deviceid, value:00:19:BB:5B:E6:BC
16:27:43 T:3120   DEBUG: ZeroconfWIN: key:features, value:0x77
16:27:43 T:3120   DEBUG: ZeroconfWIN: key:model, value:AppleTV2,1
16:27:43 T:3120   DEBUG: ZeroconfWIN: key:srcvers, value:101.28
16:27:43 T:3120   DEBUG: ZeroconfWIN: identifier: servers.airtunes type: _raop._tcp name:0019BB5BE6BC@XBMC (dc7700-PC) port:36666
16:27:43 T:3120   DEBUG: ZeroconfWIN: key:ch, value:2
16:27:43 T:3120   DEBUG: ZeroconfWIN: key:cn, value:0,1
16:27:43 T:3120   DEBUG: ZeroconfWIN: key:da, value:true
16:27:43 T:3120   DEBUG: ZeroconfWIN: key:ek, value:1
16:27:43 T:3120   DEBUG: ZeroconfWIN: key:et, value:0,1
16:27:43 T:3120   DEBUG: ZeroconfWIN: key:md, value:0,1,2
16:27:43 T:3120   DEBUG: ZeroconfWIN: key:pw, value:false
16:27:43 T:3120   DEBUG: ZeroconfWIN: key:sm, value:false
16:27:43 T:3120   DEBUG: ZeroconfWIN: key:sr, value:44100
16:27:43 T:3120   DEBUG: ZeroconfWIN: key:ss, value:16
16:27:43 T:3120   DEBUG: ZeroconfWIN: key:sv, value:false
16:27:43 T:3120   DEBUG: ZeroconfWIN: key:tp, value:UDP
16:27:43 T:3120   DEBUG: ZeroconfWIN: key:txtvers, value:1
16:27:43 T:3120   DEBUG: ZeroconfWIN: key:vn, value:3
16:27:43 T:3120   DEBUG: ZeroconfWIN: key:vs, value:130.14
16:27:43 T:1592   DEBUG: ZeroconfWIN: identifier: servers.jsonrpc-tpc type: _xbmc-jsonrpc._tcp name:XBMC (dc7700-PC) port:9090
16:27:43 T:1044   DEBUG: CVideoDatabase::RunQuery took 52 ms for 10 items query: select * from episodeview  ORDER BY dateAdded desc, idEpisode desc LIMIT 10
16:27:43 T:3064  NOTICE: Thread CRssReader start, auto delete: false
16:27:43 T:3064   DEBUG: CurlFile::Open(0AFEF7E0) http://feeds.feedburner.com/xbmc
16:27:43 T:3064    INFO: XCURL::DllLibCurlGlobal::easy_aquire - Created session to http://feeds.feedburner.com
16:27:43 T:1592   DEBUG: ZeroconfWIN: identifier: servers.webserver type: _http._tcp name:XBMC (dc7700-PC) port:80
16:27:43 T:1044   DEBUG: CVideoDatabase::RunQuery took 1 ms for 0 items query: select * from musicvideoview  ORDER BY dateAdded desc, idMVideo desc LIMIT 10
16:27:43 T:1044   DEBUG: CRecentlyAddedJob::UpdateTotal() - Running RecentlyAdded home screen update
16:27:43 T:3064   DEBUG: Got rss feed: http://feeds.feedburner.com/xbmc
16:27:43 T:3064   DEBUG: RSS feed encoding: UTF-8
16:27:43 T:3064   DEBUG: Parsed rss feed: http://feeds.feedburner.com/xbmc
16:27:43 T:3064   DEBUG: Thread CRssReader 3064 terminating
16:27:44 T:2156   DEBUG: ZeroconfWIN: XBMC (dc7700-PC)._xbmc-events._udp.local. now registered and active
16:27:44 T:2156   DEBUG: ZeroconfWIN: XBMC (dc7700-PC)._airplay._tcp.local. now registered and active
16:27:44 T:2156   DEBUG: ZeroconfWIN: 0019BB5BE6BC@XBMC (dc7700-PC)._raop._tcp.local. now registered and active
16:27:44 T:2156   DEBUG: ZeroconfWIN: XBMC (dc7700-PC)._xbmc-jsonrpc-h._tcp.local. now registered and active
16:27:44 T:2156   DEBUG: ZeroconfWIN: XBMC (dc7700-PC)._xbmc-jsonrpc._tcp.local. now registered and active
16:27:44 T:2156   DEBUG: ZeroconfWIN: XBMC (dc7700-PC)._http._tcp.local. now registered and active
16:27:49 T:2156   DEBUG: ------ Window Deinit (Pointer.xml) ------
16:27:52 T:2156   DEBUG: Activating window ID: 12006
16:27:52 T:2156   DEBUG: ------ Window Deinit (Home.xml) ------
16:27:52 T:2156   DEBUG: ------ Window Init (MusicVisualisation.xml) ------
16:27:52 T:2156    INFO: Loading skin file: MusicVisualisation.xml, load type: KEEP_IN_MEMORY
16:27:52 T:3972   DEBUG: CAnnouncementManager - Announcement: OnVolumeChanged from xbmc
16:27:52 T:3972   DEBUG: GOT ANNOUNCEMENT, type: 64, from xbmc, message OnVolumeChanged
16:27:52 T:2156   DEBUG: CPlayerCoreFactory::GetPlayers(pipe://1/)
16:27:52 T:2156   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
16:27:52 T:2156   DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
16:27:52 T:2156   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
16:27:52 T:2156   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/mms/udp
16:27:52 T:2156   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
16:27:52 T:2156   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
16:27:52 T:2156   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
16:27:52 T:2156   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
16:27:52 T:2156   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
16:27:52 T:2156   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
16:27:52 T:2156   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
16:27:52 T:2156   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
16:27:52 T:2156   DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
16:27:52 T:2156   DEBUG: CPlayerCoreFactory::GetPlayers: adding audiodefaultplayer (3)
16:27:52 T:2156   DEBUG: CPlayerCoreFactory::GetPlayers: for video=0, audio=1
16:27:52 T:2156   DEBUG: CPlayerCoreFactory::GetPlayers: adding player: PAPlayer (3)
16:27:52 T:2156   DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
16:27:52 T:2156   DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
16:27:52 T:2156   DEBUG: CPlayerCoreFactory::GetPlayers: added 2 players
16:27:52 T:2156   DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/avutil-51.dll)
16:27:52 T:2156   DEBUG: FactoryCodec - Audio: passthrough - Opening
16:27:52 T:2156   DEBUG: FactoryCodec - Audio: passthrough - Failed
16:27:52 T:2156   DEBUG: FactoryCodec - Audio: pcm - Opening
16:27:52 T:2156   DEBUG: FactoryCodec - Audio: pcm - Opened
16:27:54 T:2156    INFO: AudioDecoder: File is queued
16:27:54 T:2156    INFO: CSoftAE::MakeStream - AE_FMT_S16NE, 44100, FL,FR
16:27:54 T:3164   DEBUG: CSoftAE::Run - Sink restart flagged
16:27:54 T:3164   DEBUG: CAESinkDirectSound::IsCompatible: Formats compatible - reusing existing sink
16:27:54 T:3164    INFO: CSoftAE::InternalOpenSink - keeping old sink with : AE_FMT_FLOAT, FL,FR, 44100hz
16:27:54 T:3164   DEBUG: CSoftAE::InternalOpenSink - Using speaker layout: 2.0
16:27:54 T:3164   DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 3528
16:27:54 T:3164   DEBUG: AERemap: Downmix normalization is disabled
16:27:54 T:3164   DEBUG: CSoftAEStream::CSoftAEStream - Converting from AE_FMT_S16NE to AE_FMT_FLOAT
16:27:54 T:2156   DEBUG: AudioDecoder::GetReplayGain - Final Replaygain applied: 1.000000, Track/Album Gain 89.000000, Peak 0.000000
16:27:54 T:2156    INFO: PAPlayer::PrepareStream - Ready
16:27:54 T:2156   DEBUG: ADDON: Dll Initializing - MilkDrop
16:27:54 T:2156   DEBUG: SECTION:LoadDLL(C:\Program Files\XBMC\addons\visualization.milkdrop\MilkDrop_win32dx.vis)
16:27:54 T:1636  NOTICE: Thread PAPlayer start, auto delete: false
16:27:54 T:1636   DEBUG: PAPlayer::Process - Playback started
16:27:54 T:2156   DEBUG:   msg: Preset is not held, loading a random preset. Current is 0
16:27:54 T:2156   DEBUG:   msg: CreateDepthStencilSurface with 1920 x 1080
16:27:54 T:2156   DEBUG:   msg: Textures created!
16:27:54 T:2156   DEBUG: Calling TransferSettings for: MilkDrop
16:27:54 T:2156   DEBUG: CZipManager::GetZipList - Processing zip://special%3a%2f%2fxbmc%2faddons%2fvisualization.milkdrop%2fpresets%2fWA51-presets(265).zip/
16:27:54 T:2156   DEBUG: Visualisation::Start()
16:27:54 T:2156   DEBUG: OnInitialize() started
16:27:54 T:2156   DEBUG: Updating visualisation albumart: C:\Users\dc7700\AppData\Roaming\XBMC\cache\airtunes_album_thumb.jpg
16:27:54 T:2156   DEBUG: OnInitialize() done
16:27:54 T:2156   DEBUG: CGUIInfoManager::SetCurrentSong(pipe://1/)
16:27:54 T:2156   DEBUG: CFileItem::LoadMusicTag: loading tag information for file: pipe://1/
16:27:54 T:2156   DEBUG: Loading additional tag info for file pipe://1/
16:27:54 T:2156   DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
16:27:54 T:2156   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
16:28:13 T:2156   DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib.dll)
16:28:13 T:3120   DEBUG: Thread Jobworker 3120 terminating (autodelete)
16:28:13 T:1592   DEBUG: Thread Jobworker 1592 terminating (autodelete)
16:28:13 T:1044   DEBUG: Thread Jobworker 1044 terminating (autodelete)
16:28:14 T:2156    INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://feeds.feedburner.com (easy=0136A360, multi=003B7E60)
16:28:15 T:3164   DEBUG: CSoftAEStream::GetFrame - Underrun
16:28:22 T:2156   DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/players/dvdplayer/avutil-51.dll)
16:28:25 T:3164   DEBUG: CSoftAEStream::GetFrame - Underrun
16:28:36 T:2156   DEBUG: Previous line repeats 1 times.
16:28:36 T:2156   DEBUG: Keyboard: scancode: 0e, sym: 0008, unicode: 0008, modifier: 0
16:28:36 T:2156   DEBUG: CApplication::OnKey: backspace (f008) pressed, action is Fullscreen
16:28:36 T:2156   DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
16:28:36 T:2156   DEBUG: ------ Window Deinit (MusicVisualisation.xml) ------
16:28:36 T:2156   DEBUG: FreeVisualisation() started
16:28:36 T:2156    INFO: ADDON: Dll Stopped - MilkDrop
16:28:36 T:2156    INFO: ADDON: Dll Destroyed - MilkDrop
16:28:36 T:2156   DEBUG: FreeVisualisation() done
16:28:36 T:2156   DEBUG: CGUIWindowManager::PreviousWindow: Activate new
16:28:36 T:2156   DEBUG: ------ Window Init (Home.xml) ------
16:28:36 T:3756  NOTICE: Thread Jobworker start, auto delete: true
16:28:36 T:2156   DEBUG: ADDON: Dll Initializing - MilkDrop
16:28:36 T:2156   DEBUG:   msg: Preset is not held, loading a random preset. Current is 0
16:28:36 T:2156   DEBUG:   msg: CreateDepthStencilSurface with 1920 x 1080
16:28:36 T:2156   DEBUG:   msg: Textures created!
16:28:36 T:2156   DEBUG: Calling TransferSettings for: MilkDrop
16:28:36 T:2156   DEBUG: Visualisation::Start()
16:28:36 T:2156   DEBUG: OnInitialize() started
16:28:36 T:2156   DEBUG: OnInitialize() done
16:28:36 T:3756   DEBUG: CRecentlyAddedJob::UpdateMusic() - Running RecentlyAdded home screen update
16:28:36 T:3756   DEBUG: GetRecentlyAddedAlbumSongs() query: SELECT songview.* FROM (SELECT idAlbum FROM albumview ORDER BY idAlbum DESC LIMIT 10) AS recentalbums JOIN songview ON songview.idAlbum=recentalbums.idAlbum
16:28:36 T:3756   DEBUG: CMusicDatabase::GetRecentlyAddedAlbums query: select * from albumview where strAlbum != '' order by idAlbum desc limit 10
16:28:36 T:3756   DEBUG: CRecentlyAddedJob::UpdateVideos() - Running RecentlyAdded home screen update
16:28:36 T:3756   DEBUG: CVideoDatabase::RunQuery took 20 ms for 10 items query: select * from movieview  ORDER BY dateAdded desc, idMovie desc LIMIT 10
16:28:36 T:1920  NOTICE: Thread Jobworker start, auto delete: true
16:28:36 T:3756   DEBUG: CVideoDatabase::RunQuery took 31 ms for 10 items query: select * from episodeview  ORDER BY dateAdded desc, idEpisode desc LIMIT 10
16:28:36 T:3756   DEBUG: CVideoDatabase::RunQuery took 1 ms for 0 items query: select * from musicvideoview  ORDER BY dateAdded desc, idMVideo desc LIMIT 10
16:28:36 T:3756   DEBUG: CRecentlyAddedJob::UpdateTotal() - Running RecentlyAdded home screen update
16:28:36 T:2156   DEBUG: CApplication::OnKey: backspace (f008) pressed, action is Back
16:28:36 T:2156   DEBUG: Activating window ID: 12006
16:28:37 T:2156   DEBUG: ------ Window Deinit (Home.xml) ------
16:28:37 T:2156   DEBUG: CApplication::ExecuteXBMCAction : Translating ClearProperty(VideosDirectLink)
16:28:37 T:2156   DEBUG: CApplication::ExecuteXBMCAction : To ClearProperty(VideosDirectLink)
16:28:37 T:2156   DEBUG: FreeVisualisation() started
16:28:37 T:2156    INFO: ADDON: Dll Stopped - MilkDrop
16:28:37 T:2156    INFO: ADDON: Dll Destroyed - MilkDrop
16:28:37 T:2156   DEBUG: FreeVisualisation() done
16:28:37 T:2156   DEBUG: ------ Window Init (MusicVisualisation.xml) ------
16:28:37 T:2156   DEBUG: ADDON: Dll Initializing - MilkDrop
16:28:37 T:2156   DEBUG:   msg: Preset is not held, loading a random preset. Current is 0
16:28:37 T:2156   DEBUG:   msg: CreateDepthStencilSurface with 1920 x 1080
16:28:37 T:2156   DEBUG:   msg: Textures created!
16:28:37 T:2156   DEBUG: Calling TransferSettings for: MilkDrop
16:28:37 T:2156   DEBUG: Visualisation::Start()
16:28:37 T:2156   DEBUG: OnInitialize() started
16:28:37 T:2156   DEBUG: OnInitialize() done
16:28:37 T:2156   DEBUG: Keyboard: scancode: 0e, sym: 0008, unicode: 0008, modifier: 0
16:28:37 T:2156   DEBUG: CApplication::OnKey: backspace (f008) pressed, action is Fullscreen
16:28:38 T:2156   DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
16:28:38 T:2156   DEBUG: ------ Window Deinit (MusicVisualisation.xml) ------
16:28:38 T:2156   DEBUG: FreeVisualisation() started
16:28:38 T:2156    INFO: ADDON: Dll Stopped - MilkDrop
16:28:38 T:2156    INFO: ADDON: Dll Destroyed - MilkDrop
16:28:38 T:2156   DEBUG: FreeVisualisation() done
16:28:38 T:2156   DEBUG: CGUIWindowManager::PreviousWindow: Activate new
16:28:38 T:2156   DEBUG: ------ Window Init (Home.xml) ------
16:28:38 T:2156   DEBUG: ADDON: Dll Initializing - MilkDrop
16:28:38 T:2156   DEBUG:   msg: Preset is not held, loading a random preset. Current is 0
16:28:38 T:2156   DEBUG:   msg: CreateDepthStencilSurface with 1920 x 1080
16:28:38 T:2156   DEBUG:   msg: Textures created!
16:28:38 T:2156   DEBUG: Calling TransferSettings for: MilkDrop
16:28:38 T:2156   DEBUG: Visualisation::Start()
16:28:38 T:2156   DEBUG: OnInitialize() started
16:28:38 T:2156   DEBUG: OnInitialize() done
16:28:38 T:2156   DEBUG: Keyboard: scancode: 50, sym: 0112, unicode: 0000, modifier: 0
16:28:38 T:2156   DEBUG: CApplication::OnKey: down (f081) pressed, action is Down
16:28:39 T:2156   DEBUG: Keyboard: scancode: 50, sym: 0112, unicode: 0000, modifier: 0
16:28:39 T:2156   DEBUG: CApplication::OnKey: down (f081) pressed, action is Down
16:28:39 T:2156   DEBUG: Keyboard: scancode: 1c, sym: 000d, unicode: 000d, modifier: 0
16:28:39 T:2156   DEBUG: CApplication::OnKey: return (f00d) pressed, action is Select
16:28:39 T:2156   DEBUG: CApplication::ExecuteXBMCAction : Translating ActivateWindow(ShutdownMenu)
16:28:39 T:2156   DEBUG: CApplication::ExecuteXBMCAction : To ActivateWindow(ShutdownMenu)
16:28:39 T:2156   DEBUG: Activating window ID: 10111
16:28:39 T:2156   DEBUG: ------ Window Init (DialogButtonMenu.xml) ------
16:28:39 T:2156    INFO: Loading skin file: DialogButtonMenu.xml, load type: KEEP_IN_MEMORY
16:28:39 T:2156   DEBUG: CApplication::ExecuteXBMCAction : Translating down
16:28:39 T:2156   DEBUG: CApplication::ExecuteXBMCAction : To down
16:28:40 T:2156   DEBUG: Keyboard: scancode: 1c, sym: 000d, unicode: 000d, modifier: 0
16:28:40 T:2156   DEBUG: CApplication::OnKey: return (f00d) pressed, action is Select
16:28:40 T:2156   DEBUG: CApplication::ExecuteXBMCAction : Translating XBMC.Quit()
16:28:40 T:2156   DEBUG: CApplication::ExecuteXBMCAction : To XBMC.Quit()
16:28:40 T:2156   DEBUG: CAnnouncementManager - Announcement: OnQuit from xbmc
16:28:40 T:2156   DEBUG: GOT ANNOUNCEMENT, type: 8, from xbmc, message OnQuit
16:28:40 T:2156   DEBUG: CSaveFileStateJob::DoWork - Saving file state for audio item pipe://1/
16:28:40 T:3756   DEBUG: Thread Jobworker 3756 terminating (autodelete)
16:28:40 T:1920   DEBUG: Thread Jobworker 1920 terminating (autodelete)
16:28:40 T:2156  NOTICE: Storing total System Uptime
16:28:40 T:2156  NOTICE: Saving settings
16:28:40 T:2156  NOTICE: stop all
16:28:40 T:2156    INFO: stopping PVRManager
16:28:40 T:2156   DEBUG: CNetwork::NetworkMessage - Signaling network services to stop
16:28:40 T:2156  NOTICE: ES: Stopping event server
16:28:40 T:2156   DEBUG: ZeroconfWIN: Removed service servers.airplay
16:28:41 T:3972   DEBUG: AIRTUNES: AirPlay not running - stopping player
16:28:41 T:1636    INFO: PAPlayer::ProcessStream - Stream Finished
16:28:41 T:2156   DEBUG: ZeroconfWIN: Removed service servers.airtunes
16:28:41 T:2156   DEBUG: CNetwork::NetworkMessage - Waiting for network services to stop
16:28:41 T:2156  NOTICE: stopping zeroconf publishing
16:28:41 T:2156   DEBUG: ZeroconfWIN: Shutdown services
16:28:41 T:2156   DEBUG: ZeroconfWIN: Removed service servers.eventserver
16:28:41 T:2156   DEBUG: ZeroconfWIN: Removed service servers.jsonrpc-http
16:28:41 T:2156   DEBUG: ZeroconfWIN: Removed service servers.jsonrpc-tpc
16:28:41 T:2156   DEBUG: ZeroconfWIN: Removed service servers.webserver
16:28:41 T:2156  NOTICE: Webserver: Stopping...
16:28:41 T:2156  NOTICE: WebServer: Stopped the webserver
16:28:41 T:2156  NOTICE: Webserver: Stopped...
16:28:41 T:3164   DEBUG: CSoftAE::Run - Sink restart flagged
16:28:41 T:3164   DEBUG: CAESinkDirectSound::IsCompatible: Formats compatible - reusing existing sink
16:28:41 T:3164    INFO: CSoftAE::InternalOpenSink - keeping old sink with : AE_FMT_FLOAT, FL,FR, 44100hz
16:28:41 T:3164   DEBUG: CSoftAE::InternalOpenSink - Using speaker layout: 2.0
16:28:41 T:3164   DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 3528
16:28:41 T:1636   DEBUG: CSoftAEStream::~CSoftAEStream - Destructed
16:28:41 T:1636   DEBUG: PAPlayer::ProcessStreams - Stream Freed
16:28:41 T:2864   DEBUG: Thread CTCPServer 2864 terminating
16:28:41 T:204  NOTICE: ES: UDP Event server stopped
16:28:41 T:204   DEBUG: Thread CEventServer 204 terminating
16:28:41 T:2852   DEBUG: Thread AirPlayServer 2852 terminating
16:28:41 T:2156  NOTICE: stop player
16:28:41 T:2892   DEBUG: Thread XBMC Peripherals 2892 terminating
16:28:41 T:2156  NOTICE: stop sap announcement listener
16:28:41 T:2156  NOTICE: clean cached files!
16:28:41 T:1636   DEBUG: Thread PAPlayer 1636 terminating
16:28:41 T:2156  NOTICE: unload skin
16:28:41 T:2156    INFO: Unloading old skin ...
16:28:41 T:2156   DEBUG: ------ Window Deinit () ------
16:28:41 T:2156   DEBUG: ------ Window Deinit (Home.xml) ------
16:28:41 T:2156   DEBUG: FreeVisualisation() started
16:28:41 T:2156    INFO: ADDON: Dll Stopped - MilkDrop
16:28:41 T:2156    INFO: ADDON: Dll Destroyed - MilkDrop
16:28:41 T:2156   DEBUG: FreeVisualisation() done
16:28:41 T:2156   DEBUG: CTextureBundleXBT::Cleanup - Closed bundle
16:28:41 T:2156   DEBUG: ADDON: Stopping service addons.
16:28:41 T:2156  NOTICE: stop python
16:28:41 T:3164   DEBUG: Thread CSoftAE 3164 terminating
16:28:41 T:2156   DEBUG: CAESinkDirectSound::Deinitialize: Cleaning up
16:28:41 T:2156  NOTICE: stopped
16:28:41 T:2156  NOTICE: destroy
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in xbmc.json has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.fanart.tv has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in repository.xbmc.org has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in webinterface.default has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in pvr.argustv has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in pvr.vdr.vnsi has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in screensaver.rsxs.euphoria has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.black has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in pvr.mediaportal.tvserver has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in repository.pvr-osx32.xbmc.org has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in visualization.projectm has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in script.module.simplejson has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in weather.wunderground has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.dim has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.themoviedb.org has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in repository.pvr-ios.xbmc.org has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in xbmc.metadata has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in skin.confluence has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in visualization.glspectrum has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.amazon.de has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in script.module.pil has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in visualization.milkdrop has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in xbmc.gui has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in visualization.dxspectrum has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.musicvideos.theaudiodb.com has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in pvr.vuplus has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in xbmc.core has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in pvr.demo has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in screensaver.rsxs.solarwinds has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in xbmc.pvr has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in pvr.njoy has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in pvr.nextpvr has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in repository.pvr-android.xbmc.org has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.album.universal has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.htbackdrops.com has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in pvr.dvbviewer has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in repository.pvr-win32.xbmc.org has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.allmusic.com has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.musicbrainz.org has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.tvdb.com has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in pvr.mythtv.cmyth has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in repository.pvr-osx64.xbmc.org has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.last.fm has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.themoviedb.org has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.artists.universal has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.theaudiodb.com has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.imdb.com has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in xbmc.python has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in pvr.hts has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in screensaver.rsxs.plasma has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in visualization.waveform has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in xbmc.addon has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in script.module.pysqlite has been uninstalled.'
16:28:41 T:2156   DEBUG: ADDON: cpluff: 'Plug-in metadata.common.hdtrailers.net has been uninstalled.'
16:28:41 T:2156    INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04C47540 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
16:28:41 T:2156    INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04C470C0 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
16:28:41 T:2156    INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04C477C8 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
16:28:41 T:2156    INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04C46F10 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
16:28:41 T:2156    INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04C47618 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
16:28:41 T:2156    INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04C473D8 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
16:28:41 T:2156    INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04C46DF0 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
16:28:41 T:2156    INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04C729B8 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
16:28:41 T:2156    INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04C474F8 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
16:28:41 T:2156    INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04C46E38 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
16:28:41 T:2156  NOTICE: closing down remote control service
16:28:43 T:2156  NOTICE: unload sections
16:28:43 T:1104   DEBUG: Thread CRemoteControl 1104 terminating
16:28:43 T:2156    INFO: lastfm destroyed
16:28:43 T:2156   DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
16:28:43 T:2156   DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnClear
16:28:43 T:2156  NOTICE: destroy
16:28:43 T:2156 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
16:28:43 T:2156 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
16:28:43 T:2156 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
16:28:43 T:2156 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
16:28:43 T:2156 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
16:28:43 T:2156 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
16:28:43 T:2156 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
16:28:43 T:2156 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
16:28:43 T:2156 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
16:28:43 T:2156 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
16:28:43 T:2156 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
16:28:43 T:2156  NOTICE: closing down remote control service
16:28:43 T:2156   DEBUG: Previous line repeats 1 times.
16:28:43 T:2156  NOTICE: application stopped...
16:28:43 T:2156   DEBUG: PVRManager - destroyed
16:28:43 T:2156   DEBUG: SECTION:UnloadDll(special://xbmcbin/system/libcurl.dll)
16:28:43 T:2156   DEBUG: SECTION:UnloadAll(DLL: special://xbmcbin/system/cpluff.dll)
16:28:43 T:2156   DEBUG: SECTION:UnloadAll(DLL: special://xbmcbin/system/airplay/libshairplay-1.dll)
16:28:43 T:2156   DEBUG: SECTION:UnloadAll(DLL: C:\Program Files\XBMC\addons\visualization.milkdrop\MilkDrop_win32dx.vis)
Well it doesn't look like you played a airplay video in that log file. But it looks like something streamed music/sound as soon as xbmc was up and running. Do you have any ubuntu box in your network which uses airplay output and spams XBMC as soon as its up and running?
In that case I just streamed a music file from my ipad. But I found out, that the problem is not based on airplay.
Many files, including youtube videos or sd-video files on HDD are played too fast.
BluRay and HD-Files didn't cause any trouble.
Tomorrow I will try to disable my discrete sound- and/or graphic card to see if that changes anything.
mysterious!
The problem is gone.
I switched to "WASAPI - Speakers" and now everything is as it should.
What I can't understand: It's inpossible to reproduce the original error. I switched the settings to before (Direct Sound) - but the "play speed" was completly fine. Some minor problems with AirPlay (unstable connection), which doen't appear in WASAPI-Mode.
So if maybe anybody has a similar problem - try to check/change your audio settings.
