Full Version: Turn off the disconnections sounds?
Where can I disable the sounds occurring when DVBViewer, MediaPortClient, MythTV etc. get disconnected or cannot set up a connection? But these sounds only, not other ones. I know you can do it under Play GUI Sounds, but there you only can turn off all sounds.
And how can I turn off the pop ups displaying the disconnection (especially during watching a video)?
Only way I have found to do it is delete the actual sound files.
Thank you, teeedubb, OK, that could be a way or rename them, it would be easier to "restore".
Thanks again.
Yeah that should work too.
